Dumble video/sound clip reference, real Dumbles only please
Re: Dumble video/sound clip reference, real Dumbles only please
Could be. Phase shift caps are another common failure point in tremolos. Keep it working or keep it all original... at some point a choice has to be made.
I've always been fascinated by this particular amp, probably more so than any other SSS, because it was the only SSS originally built as a combo and with tremolo.
I really hope who ever owns it decides to send it to someone who can restore that circuit to working order. Seems like a pity to see an unique piece of HAD's works not functioning fully.
I know a partial layout was posted of it a while back, along with some discussion about how the trem circuit worked. Did anyone ever try to build their own clone of this amp?
Matt J.
Matt J.
This is an Overdrive Special played by Lap Steel player. I don’t know what gear the pedal Steel player is using.
https://youtu.be/cxXUg8B51z0?si=4seZ629U0LlznpYI
Fantastic playing, phrasing, and tone! Thank you for sharing.Nest wrote: ↑Fri Feb 02, 2024 5:53 am This is an Overdrive Special played by Lap Steel player. I don’t know what gear the pedal Steel player is using.
-Dan
4 others liked this
Robben with his 102 on That Pedal Show. Guest players as well testing the amp in detail
https://youtu.be/4z-IkXE36DI?si=nUChNhzWjxDSbtWA
Ryan
https://www.thetonegeek.com/
