Max wrote:
10% taper 250KA mid pot:
This is interesting that you know at least two amps (your own 2nd generation and this single 3rd generation) with a 10% taper 250KA mid pot. Could you perhaps post what precisely is all stamped into or written on this mid pot in your own amp, which you did measure to have a 10% taper?
RG59 coax in your own 2nd generation ODS:
If I understood correctly what you’ve posted, your 2nd generation "pre-classic" is not equipped with the usual 2nd generation grey Columbia Flexfoam coax cable (like #040 as an example) but with a RG59 coax cable. This is interesting, too. Is there anything written on the RG59 cable in your amp, be it a brand name or something else? And what is the sheath colour of the RG59 in your 2nd generation amp? And do you know the specs and dimensions (AWG or mm) of its core, its dielectric isolation and its sheath?
Max
Hi Max,
the 250 K mid pot has 250K AUD written on it,the same as the 30% pots,
so you have to measure it.I don´t think it would make big difference in the 2nd generation amps,where the Middle control doesn´t do much,
but it might matter in the 3rd generation amps, due to the missing .02
cap on the the bass pot, which makes the Middle and Bass controls more effective.
Who knows, maybe HAD used both types, similar to 80s amps, AFAIK some have 100 KL, some 100 KA (not sure which taper) for the mid pot.
The coax has no brand name on it, AFAIR the inner conductor
has a diameter of about 1 mm, overall diameter about 6 mm.I´ll
take precise measurements next time I open the amp.I´m not even sure it is RG 59, could be RG 58 as well.
BTW the connection from the FET input to the FET board is the Columbia Flexfoam too in my amp.
I really appreciate Tony´s and your efforts in this thread, I´ll be back soon
Marcos
