Well - there are amps - and there are amps.........
If you're looking for clean, there should be nothing wrong with SS, but as most guitarists are searching for " the sound", - meaning an amp that contributes to the sound, and the only form of "sound" an amp can produce, is in the form of distortion - Exactly what you DON'T want in a HiFi amplifier.
The tube/SS debate have been going on in HiFi circles for ages, and especially for PP stages, the conclusion these days, are more leaning towards the fact that both produces odd order harmonics, but tubes seems to stick to the lower order odd harmonics, 3-5 mostly, whereas SS often gives a lot more 5-7-9 th order. But even then, with todays technology, it is not uncommon to find 100W SS amps with distortion figures at a mere tenth of a percent, even at full blast. Clean at it's best! - and not wanted for guitar at all....
One thing that has not been mentioned, is the complex phase relationships that might occur when using an OT, thus maybe being the source of linear distortion - and as far as I can judge from the discussions here, not all speakers are worthwhile either....
I'm just a couple of years older than Mark and Psycho, just old enough that I actually was taught tube tech at college in the early 70s. The old professor was so stuck in tubes, that when we came to FETs - he continued to talk tubes - mostly.
One thing that came to my mind, all the tube amp simulators, that are floating around on the stomp box sites - mostly built with FETs. Have any of you tried any of these?
Some years ago, a german guy designed an AC30 simulator - allegedly so good that it was bought by VOX and pulled from the net....
