Tony, however this clip may sound to your ears – AFAIK RF used #0102 for all the concerts he played with Miles on this tour and it's visible on stage in every video of this tour I know of. And I have strong doubts that he ever used a distortion pedal in front of #0102. But of course I can't prove that your "pedal-speculation" is wrong – but a speculation it is.talbany wrote:This clip here with him playing with Miles doesn't to me sound anything like a Low Plate classic (too compressed)..Sounds like a pedal!!
http://www.youtube.com/watch?v=qKGP6y5Anm4
Here's another clip of the same solo part - but IMO with a better audio quality: https://www.youtube.com/watch?v=UQsayvE6_Pc (Solo starting around 3:00)
More clips of this tour are available in the internet and on CD and DVD. Here's an example: https://www.youtube.com/watch?v=wc_Gjndpk_0 (one of the guitar solos starting around 12:40 e.g.)
So everyone here will be able to decide if he personally perceives a pedal in front of #0102 while RF used it for this tour in combination with his maple-neck Strat.
Here's a clip from the same period together with Michael McDonald: https://www.youtube.com/watch?v=jDSLR9PVWxg&NR=1 (Solo starting around 1:50)
BTW: AFAIU it's just an educated guess based on personal perceptions of recordings like TTYD etc. that the first circuit of #0102 has been the "low-plate" version of the 4th generation "classic" ODS amps and not the "high-plate" version of the 4th generation "classic" ODS amps. AFAIK there aren't any pictures available of #0102 showing its first circuit before the skyline-update.
RF's '58 Strat:
"What do you look for in a Strat?
Everybody was playing Strats in the ’80s, and it was a good recording guitar, a good rhythm guitar. That's why I even started fooling around with one – more for accompaniment. But I finally sold my '58 dot-neck 335, and bought a '58 Strat, tobaccoburst. That's what I played with Miles Davis and later David Sanborn and my own gigs to some extent." ... "I continued to float back and forth between a Strat and the Robben Ford Model."
Source: http://www.vintageguitar.com/3401/robben-ford/
Some examples for the difference (same player, same - or at least similar - guitars, same guitar cable, same speaker-cabinet):vibratoking wrote:Yes, many have said that the FET helps bring SCs to life.
1st generation ODS - "NORMAL" input:
http://ampgarage.com/forum/viewtopic.ph ... 857#130857
2nd generation ODS - "FET" input:
http://ampgarage.com/forum/viewtopic.ph ... 483#136483 (clean intro: "NORMAL" input / Solo: "FET" input)
http://ampgarage.com/forum/viewtopic.ph ... 484#136484
http://ampgarage.com/forum/viewtopic.ph ... 802#140802
Just to avoid misunderstandings:vibratoking wrote: I am sure this is a part of the problem.
Taking into account all the professional recordings done with Dumble ODS amps in combination with single coil guitars IMO it seems to be rather obvious, that at least some or even many professional players didn't and still don't perceive any "problems" when using combinations of Dumble ODS amps and SC-guitars.
So IMO perhaps one of the most important parts of this "problem" might be the personal taste of the individual player perceiving such a "problem".
Max
