Bombacaototal wrote: ↑Fri May 13, 2022 2:30 pm
Thanks Stephen, these amps ever now and then have ways to keep us in "check" and humble.
Amen to that
I think we can summarise with these notes:
I am still carrying on the big fight with this one:
- If I plug the coupling cap of the reverb send to the master (before the send pot), no issue (this indicates that there is no issue in the supply or heaters as these are shared between send and return).
-If I plug the coupling cap of the return to the master (before the return pot) there is the issue. This indicates that it's probably something before the mixer circuit
- with reverb return set to zero there is no issue. Also indicates that the mixer circuit is fine
-If I remove the RCA return coax that goes to the recovery triode and connect PIN7 to ground, no issue but if I feed the reverb send pot OUT to the PIN7 of the return triode there is issue
-If I send the coax of the RCA return straight to the mixer PIN2 I have issues too even grounding the coupling cap of the return
**At this point it is showing that there are issues in both the RCA return and the recovery circuit**
I have narrowed down to something between the RCA return and the return recovery
- the only thing that makes the issue stop completely is removing the RCA return cable, or to remove the coax from PIN7 and the ground it, or to turn the reverb return to zero
- the weird thing I still don't get it is why, if I ground the PIn7 with the RCA return coax, the issue is still here
I wonder if the issue is elsewhere and maybe only this part of the circuit is, for some reason, picking it up. I would not know where to start. With reverb return to zero the amp is absolutely fine
The amp was fine until I amended the voltage from 240V to 120V. I have reversed that and no difference
I understand better when I can see the problem, so I've tried to make a summary of your troubleshooting in this:
So, to get to the heart of this, let's begin by ruling out what is not the issue.
- It isn't your cables or your pan.
- Grid stopper, plates and cathodes on the recovery side made no difference
- Neither did the Return pot.
- Different driver tubes also, didn't make a difference
It is telling that you say
before you amended your mains supply voltage from 240V to 120V (and then reversed it) there was no issue. Does that suggest to you that there may have been a component failure either during or after the transition, given that it was present after you reversed it as well?
Removing the RCA return cable or turning down the Return pot is of course, no solution.
Either the problem is being allowed to propagate through the circuit once the reverb return cable is attached (meaning it could be occuring downstream) or the fault lies before the return jack. As a quick test, you might try injecting a small signal at V2Bs grid and seeing if the problem persists with the return cable detached. If it is fault free there, you might conclude that the return side of the circuit is not the culprit.
I also wonder about your choice of driver, the 5751, the datasheets suggest this is more akin to the 12AX7 and has similar current capabilities. I'm sure you will find others who say that a 12AX7 can handle that position fine, maybe you are of that mind, but have you tried a more robust 12AT7 instead? Popping, crackling and fizzing all sound like a tube issue to me but I've only ever had a couple of tubes go out on me like this and they had died very shortly after.
The key event here, seems to be when you moved over from 240V to 120V, so though you seem convinced it is not a supply issue I would keep looking there.
No mention, to my recollection either, that you replaced coupling caps in the reverb circuit, but the change to higher current supply, might also have stressed a coupling cap to the point (almost) of failure especially if it was already on its last legs or in less than prime condition.
If I have missed or misunderstood anything, please let me know.
Stephen
