Clover amp
groovtubin
Clover amp
Post by groovtubin »
Re: Clover amp
boldaslove6789
Re: Clover amp
Post by boldaslove6789 »
They sound pretty good if you ask me. They use quality parts too.
llemtt
Re: Clover amp
Post by llemtt »
they are from my friend Sergio, he's a member here
I'll ping him offline to notify him of your post
cheers
teo
tubedogsmith
Re: Clover amp
Post by tubedogsmith »
that sounded quite cool, had the G Hilden thing going on bigtime!!
Re: Clover amp
Sounds good!
sergio
Re: Clover amp
Post by sergio »
Hello everyone , it's a long time since I don't post, but I always read the forum and read interesting information.
Greetings to all members and Teo.
Sergio
ToneMerc
Re: Clover amp
Post by ToneMerc »
Very nice indeed.
TM
SuperReverb2
Re: Clover amp
Post by SuperReverb2 »
The amps are made in Italy and they are designed to run on 230 volts AC. What problems does that cause if one wanted to use one of these amps in North America on 120 volts AC? I'm assuming there are transformers available to convert 120 to 230? Other than the hassle, does this cause any problems with the amp if done correctly. I'm assuming this has been done successfully many times before as I'm assuming there are many 110 - 120 volt AC amps in Europe. Anybody have any first hand experience at this? Thanks for your time.
Re: Clover amp
I suppose the simple solution would be to use a variac with a foreign amp.
But the best fix would be to have a export power transformer that has both 120vac and 220vac primaries.
Some amps like Marshall were switchable.
SuperReverb2
Re: Clover amp
Thanks. Agreed. Staco makes a decent Variac that will work for this. (just got off the phone with them actually) 4.8 amps at 230 volts AC. Expensive with the built in voltmeter though. Yikes!! I'll contact the builder and see about a different transformer. I know Van Weelden went through the same thing for the US amps he built for Joe Bonamassa.
groovtubin
Re: Clover amp
tubedogsmith wrote:that sounded quite cool, had the G Hilden thing going on bigtime!!
i blv it wqs cloned from that amp, even the footswitch looks same as Greg`s!
grtamp
Re: Clover amp
Post by grtamp »
Sounds good! , very sweet tone!
