Hi gang,
before using some of these in my 70s Hybrid I thought I ask if somebody has used these in Dumble style circuits.
I tried them in the past, but could not for the life of me find anything special.
The caps are marked ITW and are sort of like Blue drops from a 70s silver-face Fender PA 100 head.
Thanks for any info on these!
Electron
Blue dipped ITW caps (salvaged from Fender PA head SF)
- ElectronAvalanche
Re: Blue dipped ITW caps (salvaged from Fender PA head SF)
Most likely polyester.
I remember someone saying that the earlier polyester molded caps sounded different (better?) than the currently made Orange Drop polyester caps.
I would probably try them after checking for leakage.
- ElectronAvalanche
Thanks Tom!
but how to test leakage? I have a scope somewhere and a VM of course.
I searched the web and testing seems to be a bit of a hassle. I could use clips and hang the caps in my other amps from a B+ and then test for DC leakage with my VM?
Leakge has to be tested at operating voltages right?
Electron
Electron
re
Yep. One end to a B+ of working voltage, the other end to a VOM set to read voltage. Depending on the internal resistance of the VOM, you shouldn't see anything more than a fraction of a volt. Those blue-drop caps are actually pretty good in terms of reliability and being non-microphonic.
NO problem using them sparingly in my builds, like the pi secondary feed, and hrm ts..ElectronAvalanche wrote:Hi gang,
Electron
- ElectronAvalanche
Hi all,
thanks for the tips! I will try them in the PI and TS for this build!
Electron
Electron
Thanks for this thread! Just got a bunch the other day, didn't know if they were any good.
- renshen1957
HiElectronAvalanche wrote:Thanks Tom!
Electron
Check out ebay for a tube powered capacitor tester (Heathkit). These work at B+ voltages.
Best Regards,
Steve
