ODS #77 for auction
ODS #77 for auction
http://entertainment.ha.com/c/item.zx?s ... otNo=54225
Nice hi-rez pics of the front and back. No gutshots. Looks like somebody added an extra master.
-Aaron
-Aaron
Re: ODS #77 for auction
Good luck to them.
20k opening bid plus 25% buyers premium , and its busted.
John
John
and poorly modified if they put the master pot through the dumble logo.and its busted.
maybe HAD will fix it for you for an extra 25k +-?
Plus valve effects loop (dumbleator?)
groovtubin
077
looks to me that HAD modded it, look at the LOOP fonts above the send and return!
That allows it to stay vintage. Fixing it & having it actually work would probably dramatically lower the value of the amp.and its busted.
With respect, 10thtx
Hi everyone,
could somebody perhaps upload the high resolution pics of 77?
thanks alot.
thanks alot.
High resolution images of the front and back of #77.
- boldaslove6789
Jeeze, couldn't even spring for some matching mini toggle switches.....
Guess this amp got a Skyline Update and an added Ratio control, maybe he changed out the Mini toggle when in for service/update? Hard to tell if HAD added the Extra Loop.... Its possible though, seems the orig owner had a consistent relationship with HAD so its possible (he past away and his widow had 2 ODS amps she was trying to sell for big $. Pretty sure the other was a 5th gen Blackface Skyline amp.
Greg D.C.
Can you dig it?
(NEW VIDS here!!) http://www.youtube.com/user/GDClarkProject
http://quinnamp.com/ http://www.prairiewoodguitars.com/
http://www.funkymunkpedals.com/
Can you dig it?
Hi aflynt,
thanks alot for the uploads!
Why do you think that Alexander Dumble added the small "in" and "out" switch and the red "in" and "out" and "send" and "return" script and not some other tech?groovtubin wrote:looks to me that HAD modded it, look at the LOOP fonts above the send and return!
Greg, why do you assume a Skyline update? And why do you think that this amp hasn't been originally built with the "ratio" control on the front but that the "ratio" control on the front has been added at some later point?boldaslove6789 wrote:Guess this amp got a Skyline Update and an added Ratio control.
MaxMax wrote:Why do you think that Alexander Dumble added the small "in" and "out" switch and the red "in" and "out" and "send" and "return" script and not some other tech?groovtubin wrote:looks to me that HAD modded it, look at the LOOP fonts above the send and return!
Wasn't #075 a transition generation amp and one of the first to get the Ratio control installed (on Back)..Also I assume the control on the back of 077 is the OD trigger or possibly fet gain control..Do you know which?
http://www.audities.org/audities/collec ... ive_a.html
Therefore this would make some sense shortly after 075 was modded to Steve's liking that he began installing them on the front correct
The bright switch was more than likely failed and replaced..
BTW..The red toggle switches look stock..If a skyliner update was done he would have most likely changed the deep on the front, unless he had another red toggle in his drawer..
Have a Great one!!
Tony, the ODS #0075 of Steve Farris is indeed a "transition generation" ODS with a ratio control and a presence control and reportedly with a "classic" tone stack and a" standard" OD circuit with the trigger entrance. According to Andy Brauer's eBay description (see Rob Livesey's page) when he sold the amp on behalf of Steve Farris # 0075 seems to be the first ODS built with a ratio control. The ratio control of #0075 is placed on the back and the full grown presence control is on the front. Because of the ratio control on the back of #0075 the loop of #0075 is a stereo jack.talbany wrote:Wasn't #075 a transition generation amp and one of the first to get the Ratio control installed (on Back)..
No, I don't know this for sure. But of course these are two possibilities in regard to the function of the control with the (unusual on a Dumble) Fender style knob on the back of #0077. Another possibility might be that it's some control related to what might be a buffered loop (4 preamp tubes).Also I assume the control on the back of 077 is the OD trigger or possibly fet gain control..Do you know which?
I'm not sure if the ratio control of #0075 was one of the (many) custom mods of #0075 Steve Farris asked for when buying it and/or while he owned it, or if the ratio control was an idea Alexander Dumble himself came up with. AFAIR right now all the other transition generation amps - including #0077 - have the ratio control on the front - but many of the other transition generation amps don't have a (small or large) presence control but still an accent switch - just like #0077.Therefore this would make some sense shortly after 075 was modded to Steve's liking that he began installing them on the front correct
Yes, most probably.The bright switch was more than likely failed and replaced..
At least you'll find them on many Dumble amps from the same period.BTW..The red toggle switches look stock.
All the best,
Max
Thanks Max!!
Have a Good one!!
T
Have a Good one!!
T
tjauernig
I worked with Kimbo from 2007 to 2010. We were both at Peavey. He was a sales rep, and I was the head designer in the custom amp shop at the time. I played this amp several times. (as well as the ODS head he had) All the mods were done by Dumble in an effort to get this amp closer to the sound of the head. It never quite got there. Kimbo did not particularily like this amp. The head was incredible though. (I've posted about the head in the past)
T. Jauernig
