OD channel tone control ?
10thTx
Post by 10thTx »
At times, I have wondered why there have not been more posts about some type of tone control for the OD channels on the D-clones?
Over this last yr or so, I have gotten a couple of questions regarding the "psuedo" 5E3 tone control that I use on my Tweed BluezMeister and D'Mars ODS amps (D-inspired amps) .
I am very happy with it and find it very useful to dial in the tone that I want on those amps. I feel like I benefit from a tone control both on the clean and OD channels.
I've seen the HRM tone controls that are typically internally trim pots. And I've seen something similar to a "cut" control on the OD.
Anyone else have an OD tone control that they are happy with where the pot is external vs an internal trimmer?
With respect, 10thtx
hywelg
Re: OD channel tone control ?
Post by hywelg »
Well I have just put the 12 way cut control the DrIka (Pickmaster) posted on the Ceriatone forum into mine. It works really well and allows me to have the clean channel as bright as I want it whilst keeping the OD tamed.
I moved the presence to the rear panel (as a temporary measure) under the OD trim control and installed the 12 way rotary in its place. I am finding that i do use the Cut differently with different amp settings or different guitars so it looks like it will have to stay. I was thinking I would find one value cap that would serve for all instances but thats not turning out to be the case.
ChrisM
Post by ChrisM »
What's the rotary switch doing?
Looks like a cap from the pot's input to ground, so shunting some highs to ground.
hywelg
Post by hywelg »
ChrisM wrote:What's the rotary switch doing?
Indeed. Though I did wonder if it might be better to connect to the wiper? Maybe will try that at some point.
Various cap sizes up to 2.2n, and a NC. I only used 10 of the 12 available switch positions. Cap values, IIRC 38p, 56p, 82p, 120p, 220p, 390p, 500p, 680p, 1n, and 2.2n. If I had a better spread of values available I would have had more options in the 100-500p range as this seems to be where I am using it most.
ChrisM
Post by ChrisM »
If you connect the control from the wiper you'd have more resistance in series with the control (150K + the resistance from lug 3 to 2).
This would shift the cutoff frequency of the low pass filter lower.
10thTx
Post by 10thTx »
12 way cut control
IF you could determine which 3 values you use the most, then perhaps you could use a spdt center off and parallel the outside values to get the top three "cuts" that you use the most frequently.
Doing it that way .......... you could use a mini-toggle.
hywelg
Post by hywelg »
I'm using between 100pf and 390pf at the moment so I doubt I could narrow it down to 2 (flus off is always a good idea)
10thTx
Post by 10thTx »
So, if your amp settings on the cut control had been monitored ..........
Do you have a "best guess" as to which three of those between 100p & 390p you use most frequently?
My guitar has a 5 way switch. I use all 5 positions. Two of those 5 positions, I use more than the rest.
I'm trying to think thru that if space were truly an issue, which 3 would be the most useful on a center off spdt?
hywelg
Post by hywelg »
10thTx wrote: I'm trying to think thru that if space were truly an issue, which 3 would be the most useful on a center off spdt?
Probably 100p and 220p, but its still early days yet. Still haven't tried my LP through it though my HSS strat has a Fralin Unbucker in the bridge.
10thTx
Post by 10thTx »
OK, then you could do 100p center off using a mini-toggle.
120p on one side for 220p.
270p on the other side for 370p.
That would cover the 100p -370p range.
Thank you for the response! With respect, 10thtx
hywelg
Post by hywelg »
I did mean I would also want a true OFF, just for comparison. In that scenario I would put a Push Pull tone cut bypass on the Level pot.
And its also relevant that I have a 680p snubber on V2b which I will revert to stock and then re-evaluate.
JazzGuitarGimp
Post by JazzGuitarGimp »
Hi 10thTx,
I would imagine the 100K trim pot at the front end is a linear taper, but what about the 100K OD Gain and OD Level pots? Are these log taper?
Many thanks,
Lou
Lou Rossi Designs
and Schematic Capture
10thTx
Post by 10thTx »
I believe these are 100ka audio.
JazzGuitarGimp
Good to know - thanks!
Lou Rossi Designs
tictac
Post by tictac »
Actually they are linear taper; I used to have audio taper for the Drive (Gain) control and I put a linear taper in there and it really does give you better control of the overdrive. See the Ford ODS schematic for reference...
A converted sceptic...
TT
