Dumble Modified Bassman Ebay
andyhardy
Post by andyhardy »
Re: Dumble Modified Bassman Ebay
That's the amp from the Todd Epstein estate that had the #180 Dumble.
[img:1200:1600]http://i.ebayimg.com/t/DUMBLE-OVERDRIVE ... ~60_57.JPG[/img]
dreric
Post by dreric »
Structo wrote:That's the amp from the Todd Epstein estate that had the #180 Dumble.
I dunno ..............no shirtless guy
Eric
Eric
:lol:
ATL Strat
Post by ATL Strat »
Anyone have any idea what mods were done to this Bassman? I've got a hacked up Bassman (someone else's hack job) in need of a new life.
David Root
Post by David Root »
Mepco-Electra metal films on the PI, plus orange drops. Too bad can't tell if the values are changed. Three chocodrop caps. Carbon comp PI cathode and tail resistor changed to carbon film, Piher/Beyschlag probably. Cathode bypass caps on V3 changed to Sprague 5uF.
I'll compare this layout with the stock Leo layout. Is '62 a 6G6A or 6G6B?
David Root
6G6B. Would take a lot of work to decipher those two pots.
talbany
Post by talbany »
David Root wrote:Mepco-Electra metal films on the PI, plus orange drops. Too bad can't tell if the values are changed. Three chocodrop caps. Carbon comp PI cathode and tail resistor changed to carbon film, Piher/Beyschlag probably. Cathode bypass caps on V3 changed to Sprague 5uF.
Dave
Those PI vales are fairly critical so they more than likely drifted to far out of spec.. The 1'st channel (cathode follower TS) looks like it could be voiced more for bass guitar..For me this amp has a cool factor of about a 5.. :shock:
renshen1957
Post by renshen1957 »
Dave
The amp sold for US $6,106.00
[ 18 bids ] on Feb 17th.
The ODS 100 sold $55,600.00 (12 bids) on Feb 12
Best regards,
Steve
ToneMerc
Post by ToneMerc »
David Root wrote:6G6B. Would take a lot of work to decipher those two pots.
Pot- MV
3way switch - channel jumping and a pad for the bass channel?????
I can certainly understand a pad for the bass channel. The two 6G6B's that I built which had modded bass channels, the bass channel was much louder than the normal channel.
TM
ToneMerc
Post by ToneMerc »
talbany wrote:
Dave
He didn't even change the slope resistor value.
TM
qtone
Post by qtone »
It dawns on me the shirtless pic was just them including a GUT SHOT ahead of time.
I lost that bid..
