LT Spice Error
Krinkle
LT Spice Error
Post by Krinkle »
I downloaded LT Spice and created the V1a section of the SSS just for kicks and when I try to run the simulation I get this error;
"Unknown sub circuit called in xv1a n002 n005 n006 triode"
I didn't create a heater node, would this be the problem?
Triode model is Duncan's.
markusw
Re: LT Spice Error
Post by markusw »
Did you add the ".INC dmtriodep.inc" directive?
Basically, you need to include the library file that contains your triode model.
Krinkle
Re: LT Spice Error
Post by Krinkle »
Thanks for the reply Marcus. I used these and they worked right away. I'll pick up the nuances of SPICE as I go along.
http://www.diyaudio.com/forums/software ... uit-2.html
