I finally finished initial assembly on the 3rd-4th Gen Hybrid 50 W ODS Low-Plate-Classic build.
But I think I have something wrong at the power tube sockets. Not sure though. The reason that I suspect that, is because I normally use a "Bias King" tool to set power tube bias - and for some reason, it's not seeing any idle current on the power tubes in my new build. I have never seen this before - which is why I suspect I have something wrong at the power tube sockets.
I know I'll probably need to take some pics - but here are the numbers...
[PT = Mag Components - Classic Tone #40-18005]
B+1 = 465 VDC
B+2 = 464 VDC
B+3 = 442 VDC
B+4 = 308 VDC
B+5 = 299 VDC
I think that only the first two are relevant to the power tubes - but that's all of them.
On the sockets:
P1 = nc
P2 = 6.6 VAC (between 2 and 7)
P3 = 463 VDC
P4 = 462 VDC
P5 = -48 VDC (adjusted for maximum negative bias voltage)
P6 = nc
P7 = 6.6 VAC (between 2 and 7)
P8 = ground
Any glaring problems with these numbers?
I would expect the Bias King to display the idle current - but it's not.
I wonder if it expects pin 1 to be tied to pin 8
If these numbers look as they should then I'll have to investigate why the bias tool isn't displaying idle current draw.
As always - many thanks.
-Paul
