Here is a subject that has been discuted before, but I can't find any precise answer on the forum.
I work with ODS schematics for a while now, and I always get some awfull hiss on OD channel when I turn up the gain and volume controls, even with no signal on the input.
I use this type of schematic : https://ampgarage.com/forum/download/fi ... &mode=view
Edit : I talk about a big oscillation at high frequencies, more than just a hum or soft hiss when the amp is cranked up.
I did a lot of experiments : OD tube voltages, swapping snubber caps, pots, playing with the trim, etc... But I always get hiss at some point, especially at high gain level of course, but also with high volume and mid gain. There is perhaps a "perfect combination" of all that, but I didn't found it
I read that there is often some hiss with Dumble designs, but I can't believe that Dumble sold amps with hiss, even at high levels. So did I miss something ? Is it a way to have a responsive but quiet OD channel ?
Thanks for your help.
Cyril.
