This is what I would like to build. I would like to make a digital layout of it before proceeding forward. Can anyone help me turn this into a digital layout?
4x 6L6, non FET, non HRM, non skyline, 250K treble and bass pots, 100K mid pot, 330pf treble cap, 100K slope, .047 mid, .01 bass, bigger cathode bypass caps (10-25uf)on the clean side and 100K/1K5 plate/cathode resistors. SSS type Hi and Low filter switches, 2 tube reverb with send and return both on front panel,
I don’t know how to use Visio. That’s what I’m trying to find help with. I only have Mac computers. Don’t know how to use much Microsoft stuff. I appreciate the link tho. Do you know who on here is good with Visio?
There is DIY Layout Creator. It's a fairly mature product. Flexible, not hard to learn, and it runs on Macs.
Slucky and others here have invested a lot of time (and money) honing their Visio chops, but I don't know if I'd feel comfortable asking them to make a layout from scratch for me. If they already have something close that they can edit quickly, then they'll probably step forward on their own.
If it were me, I'd collect existing layouts of amps with features I want to include and create my own layout with diylc. If you present something here, even a work in progress, I think you'll probably get useful feedback from the wise ones.
My own attitude is that I enjoy helping people that are trying to learn but not particularly interested in doing the work for them. As a general rule, I'll work as hard as they need me to, but never harder than them.
dr. who wrote: ↑Mon Feb 18, 2019 6:01 pm
There are some that are, but I thought Microsoft had yet to port Visio to the Mac?
The mentioned DIY Layout creator was mentioned because it works on windows/linux/mac and is getting constant support from the dev. There's a very active group on facebook covering it's use, and Doug Hoffman's turret building software can take the boards designed on it and convert them to a turret/eyelet board for you pretty easily.
As sluckey mentioned, the layout comes after the schematic, I think he's asking because he's a visio whiz and may already have layouts for some things that are pretty common and that he may have as a starting point for you.
Again, though, not having a windows PC makes visio not an option.
I have an old laptop that I keep for Visio only. Can make a coffee while it starts up
Are you wanting circuitboards/layout or the wiring as well? Sometimes doing an amp from scratch on Visio takes about the same time as building one.
I’m really OCD and the visual layout make me feel a lot more comfortable starting off. I’ve built one ODS before and I would have never finished without a visual layout and help from Taylor, Jelle, and Brandon. Right now I have two friends wanting the circuit I mentioned. That’s why I was trying to find someone that’s good with the program that will help me figure out what to change, where to change it, and how to change it. This program should be kind of like legos I think. My problem is with the reverb, the hi and low filter switches, as I haven’t much knowledge of them. Is there an ODSR file already? Maybe that would be the easiest to take from. After I can figure this out I want to then go to the topography of the 150 ODSR on smaller output sizes. If it’s not too outrageous I would pay for someone to digitize this design and walk me through changing some things on it so I can start going from there onto other new things like 183 ODSR and such. I hope this clarifies things a bit. Thanks
For <dayjob> related tasks the web-based draw.io has been effective as a visio compatible viewer/editor. Some glitches and functional gaps but was often able to get what was needed. Offer it only FYI as something to experiment with, given hands-on experience is quite limited. Plan to someday test out whether it's adequate to upload some visio-based amp layouts and enable my design edits. Not this month however.
Update: did a quick search for an example and downloaded VSD from here https://ampgarage.com/forum/viewtopic.p ... 34#p152843, and it loaded OK into the app. In a few minutes did some quick tests to confirm renderings and basics of copy/paste, object moves, etc worked. Unclear if the original VSD had proper "connections" on objects. If so, then those apparently broke during import. Creating a "connect" was easy, and it then did work. Far from proof it's 100% workable but would recommend "test drive" to others.
