#183 bass pot
grtamp
#183 bass pot
Post by grtamp »
Hi, can I use 500K for bass pot in the #183?
I can see 300k, but is not a standard value.
rccolgan
Re: #183 bass pot
Post by rccolgan »
I use these 300k pots on guitars https://amzn.to/3yOC49X and you can slip on one of these adapters https://www.amplifiedparts.com/products ... t-shaft-14
another thing you can do is use a 500k potentiometer and add a resistor across legs 1 and 3. 820k ohm would be good to get you ~311k
Last thing is see if any of these will work https://www.mouser.com/c/passive-compon ... 00%20kOhms
Let us know what direction you go!
Ryan
https://www.thetonegeek.com/
ijedouglas
Re: #183 bass pot
Post by ijedouglas »
grtamp wrote: ↑Tue Oct 18, 2022 10:02 am Hi, can I use 500K for bass pot in the #183?
I used Alpha pots that measured low. I think if you get around 350K to 400K you should be good.
Ian
grtamp
Re: #183 bass pot
Post by grtamp »
Thanks Ryan and Ian :wink:
Colossal
Re: #183 bass pot
Post by Colossal »
Careful with those Bourns pots. I tried them once and they ALL measured unacceptably low. I go the 500k/820k strapped route.
grtamp
Re: #183 bass pot
Post by grtamp »
checked, mine has 311k value :wink:
ijedouglas
Re: #183 bass pot
grtamp wrote: ↑Mon Oct 24, 2022 10:04 am checked, mine has 311k value :wink:
Great!
I would try and see if you have something a little bigger. I tried a 310K but preferred one around 350K.
BTW, I think the 311K from Shad was an incorrect reading as it may have been in circuit.
Ian
