11 Step High and Low Filter Section
Anyone has info or an approximation of how a 11 Step High- Low Filter section schematic be like? What would be the values that make sense?
- Funkalicousgroove
3 others liked this
Re: 11 Step High and Low Filter Section
Since the low filter is basically a 1M RA pot , I’d say simply divide the existing resistor values such that you’re about 85% through the resistance about 1/2 way through the rotation. Basically you get smaller increments.
The high filter you can add in-between values, lower values, or higher values depending on what you’re trying to achieve.
The real problem might be finding an 11 position switch
Feels great to get a reply from the legend himselfFunkalicousgroove wrote: ↑Tue Oct 29, 2024 7:11 pm Since the low filter is basically a 1M RA pot , I’d say simply divide the existing resistor values such that you’re about 85% through the resistance about 1/2 way through the rotation. Basically you get smaller increments.
The real problem might be finding an 11 position switch![]()
