Here is a clip of the rev-a-loop. Guitar is a Fender Strat into my Super Overdrive 50 amp. Clip was recorded flat with no EQ or compression.
Speaker is a 1x12 Tonker loaded cabinet.
Let me know what you think....
Sorry for the rambling on the clip. Kinda sounds like Bugs Henderson
Gary
www.glaswerks.com/media/revaloop.mp3
Rev-A-Loop Clips
- glasman
Rev-A-Loop Clips
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
- ElectronAvalanche
Re: Rev-A-Loop Clips
Hi Gary,
great clip!!
I especially liked the narration and explanations!
The Reverb sounds very nice.
Where do you think the hum is coming from?
Maybe you could try to use some NLF either on the Reverb driver tube or on the Recovery section to smooth out the Reverb a bit more.
I personally do not like too much Dwell btw. Really like the Dwell up to 12 o`clock on the clip.
I really like the Clean sound of your amp bwt.
So did you parallel the Reverb Recovery tube systems yet?
If you look at Bens schemo of the 70s ODS Reverb, you should maybe try (as mentioned above) the Feedback on the Driver tube (820k with 0.05uF cap if I remember correctly).
BTW: if you find an old used spring Reverb from a Hammond organ (these can be found real cheap on evilbay) you should give these a try. They do sound much smoother than the new Accutronics.
Thanks again!
I am tempted to build a Reverb-A-Loop myself. I already have a nice PS for a Rack Dumbleator but only heater current for 2 tubes for that.
Maybe I should try a one tube Reverb ckt then?
Electron
great clip!!
Thanks again!
Electron
- glasman
Thanks, the comments on the narration, still sound like Bugs' liner note on his albumsElectronAvalanche wrote:Hi Gary,
great clip!!
(if you don't know Bugs Henderson, go to http://www.bugshenderson.com )
The hum is a low level signal that is being picked up by the Reverb tank output coil. I tried DC on the filaments to see if that was the issue but there was no difference. There is probably still one ground loop left that I still need to find. It is probably that the recovery amp ground and the reverb output tank ground are at separate locations.
I looked at that and might give it a try and see how it sounds. I looked at the 70's ODR will try it next time I open the box.
I usually keep it set between 11:00 and 1:00. The tone control really does a nice job of tailoring the overall reverb effect. Gets rid of a lot of the Elca BOING factor.I personally do not like too much Dwell btw. Really like the Dwell up to 12 o`clock on the clip.
Thanks for the comments on the amp. I kinda like it too
Yes, I did parallel the sections of the recovery amp. Two stages of gain was too much. The parallel sections sound much better.
The NFB is something that I will try.
I have heard comments on the old Hammond tanks. Problem for me is that I will need a steady flow of tanks in time. Bext for me is to figure how to make the new ones work. I have never tried them, but the Belton tanks are suppose to be even worse that the new Accu's. Actually rolling the tone control to between 12:00 and 2:00 really smooths out the sound.
Thanks again!
Electron
The one tube circuit would work just about as well. Ask Dogears about the reverb I built into his amp. It is the one tube circuit that picks up the signal just before the loop and injects the reverb signal into the recovery amp. It can really go over the top as well!
Thanks for the comments.
Gary
www.glaswerks.com
www.glaswerks.com
Thanks for posting the clip I really like the sound of the reverb (and the amp as well).
- glasman
Thanks much. The amp is my original build from a couple of years ago.tonelab2 wrote:Thanks for posting the clip I really like the sound of the reverb (and the amp as well).
It has been a real work horse.
Gary
www.glaswerks.com
www.glaswerks.com
