Trim Potis inside of the Ceriatone
GregorHIlden
Post by GregorHIlden »
Hi Folks, I just got me a Ceriatone Top since a guitarplayer here in germany had this one for sale. So I bought it to check out the amp.
The first channel sounds really nice - but the Overdrive Channel is not what I want. It has way too much gain and if I reduce the gain, the channel is not as loud as the first channel.
I saw two trimmers inside the amp. I labeled "1" and "2" on my picture. Could anybody tell me wich pot I have to adjust to change the OD-Channel only? I want to leave the fist channel like it is, so I don't want to dial the wrong trimmer...
Thanks for answering, Gregor
heisthl
Re: Trim Potis inside of the Ceriatone
Post by heisthl »
#1 is the overdrive entrance trimmer. #2 sets the Phase Inverter balance which hopefully is ok since you're happy with the clean tone.
www.RedPlateAmps.com
GregorHIlden
heisthl wrote:#1 is the overdrive entrance trimmer. #2 sets the Phase Inverter balance which hopefully is ok since you're happy with the clean tone.
Thanks a lot - I will check this out! All the best, Gregor
JD0x0
Post by JD0x0 »
setting the OD trimmer to about 9 o'clock is a really great area for lower gain tones. but let your ears be the guide.
which ceriatone OTS model is that?
-JD
GregorHIlden
JD0x0 wrote:setting the OD trimmer to about 9 o'clock is a really great area for lower gain tones. but let your ears be the guide.
-JD
Thanks. It is a new OTS with 50 Watt
JImmyD
Post by JImmyD »
Hi Gregor, welcome to the OTS club. Best power tubes I've heard to date in the amp have been Svetlana Winged C. Not sure what is in yours, but the JJ's from the factory do not necessarily let the amp shine.
Continued success to you.
Regards,
Jim
jaysg
Post by jaysg »
GregorHIlden wrote:It is a new OTS with 50 Watt
Will you be trying to mod it to sound like your old OS, or something different?
GregorHIlden
JImmyD wrote:Hi Gregor, welcome to the OTS club. Best power tubes I've heard to date in the amp have been Svetlana Winged C. Not sure what is in yours, but the JJ's from the factory do not necessarily let the amp shine.
Regards,
Jim
Hi Jim, I even have noticed what tubes inside - but after trimming on the inside pots the amp sounds good now. Was horrible gainy and compressed on the OD channel before.... Gregor
GregorHIlden
It is not possible to get 100% the sound of the #94 Dumble I had - but after trimming I think the amp is really good now. But I'm only able to say more after a gig. It's different when you play amps at home or on stage.. got the chassis only and ordered a cabinet yesterday, so it will takes some weeks befor I can check the am live. All the best, Gregor
JD0x0
Post by JD0x0 »
Regards,
Jim
i changed my preamp tubes to Tungsol 12AX7's any my power amp tubes to Tungsol 5881's and it makes tuch a huge difference. the OD is smoother and the cleans improved so much
Thilo278
Post by Thilo278 »
Hallo Gregor,
ich frag einfach mal auf deutsch, mein Englisch ist nicht das beste ;)
Wurde der Amp gemoddet oder ist der Amp stock? Was für einen Speaker benutzt du?
Ich besitze auch einen OTS und versuche das beste aus ihm herauszuholen und da du ja selbst einen Dumble besessen hast, denke ich, dass du das gut beurteilen kannst :D
And for everyone who isn't able to understand German:
Did you mod your amp or is it stock? Which speaker do you use? I own an OTS, too, and I'm trying to get the best out of it.
Thilo
GregorHIlden
Thilo278 wrote:Hallo Gregor,
Thilo
I think amp is stock, the Vox 2 x 12 Blue Alnico Cab works great
Steven_nl
Dumble
Post by Steven_nl »
This is the greatest joke ever. A Dumble owner who bought a Ceriatone.
Welcome to the club. Obviously I'd love to hear your opinion.:-)
Thilo278
Post by Thilo278 »
Well, i like it :)
I (an 18 year old student from germany) would NEVER be able to afford some of the more expensive d-clones or a real dumble, so i'm really happy to hear that this amp is good from him (I really like his playing and tone).
and it tells me that i made the right decision with buying this amp.
I don't see anything wrong with them at all.
A very good bargain, and very tweakable platform to experiment with. :wink:
