Manzamp - Revisited!
- dorrisant
7 others liked this
Hello to all...
As a mission to fill a void, I have been working out a better layout than the original for the Manzamp. Not to take anything away from ic-racer, his build was emaculate!!
https://ampgarage.com/forum/viewtopic.php?t=19782
Kuddos to him for all of his efforts. Problem is, most of his photos are gone. I have tapped a source and now have them. First, I present the schematics considered in the above post, then the layout and PCB traces. Note: between the two schematics you can derive the voltages as well as the part numbers for the TX set. I am posting the datasheets for specs only.
- dorrisant
Re: Manzamp - Revisited!
In the PCB layout, I modified it to conform to the schematic. I made the pin spacing 10mm for the reservoir caps and 7.5mm for the rest of the power supply electrolytics. All through holes are 1mm and the eyelet holes are .125". The boards are 11" x 2.75". I will probably make a few of these PCBs. I will CNC engrave them on copper clad. Email me if interested (address on layout). Otherwise, grab the .rar file for several file forms to use for your own iteration. The PDF and DXF files should be 1:1. Let me know if there is another file form to be added.
***Edit*** I have made some of these boards. I think they turned out well.
- dorrisant
2 others liked this
Now for the pics...
Arrange them how you see fit. I'm dumping them in alphabetical order.
- dorrisant
2 others liked this
More...
- dorrisant
More...
- dorrisant
More...
- dorrisant
More...
- dorrisant
More...
- dorrisant
More...
NOTE: The PCB layout in this post is earlier work that has an error in it. I would not suggest using this. I just posted it for authenticity.
- dorrisant
More...
- dorrisant
2 others liked this
This is the last of it. Sorry if there were any duplicates. Enjoy!! I'm goin' to bed now.
- Reeltarded
Wow. Until I heard UP this was my favorite clean amp.
That is amazing. Seriously great work!
Outstanding!
Thank you for compiling this.
D
D
Stickied! Outstanding detail and work, hope we see a ton of builds
- dorrisant
5 others liked this
Thanks guys! Just trying to give back.
Here is a clip of ic-racer's build:
https://youtu.be/jRGgZZ7jjkk
And others
https://youtu.be/FGUPyKYz3Xo
https://www.youtube.com/watch?v=jRGgZZ7jjkk
https://www.youtube.com/watch?v=FGUPyKYz3Xo
https://www.youtube.com/watch?v=PbLJk2dhFPo&t=31s
https://www.youtube.com/watch?v=b9qjeU0XBgg
And others
