BM_Build in a Funk_Chassis
Just finished this one, haven't heard it yet. It got the BM stack,PI and PAB. If there's sufficient interest I'll post the schematic.
www.RedPlateAmps.com
Re: BM_Build in a Funk_Chassis
More Pics
Please post the schem...
TIA!
Jelle
TIA!
Jelle
Wow
Gorgeous !
Is there an half power switch in the back ? Does it have two masters ? Yes it would be cool to see the schem![Cool 8)](./images/smilies/icon_cool.gif)
mat
For those of you that "paint by numbers" there is an error in the photos - the bias caps are backwards (aaaaargh!!!!) luckily I caught this before I powered it on. With no tweaking at all this thing sounds amazing - good enough to post the schematic as built. It has a much fuller clean tone (read hotter) and the OD is very respectable (maybe a touch bright, but not annoyingly so) until you hit the boost and then its incredible, in a very non-HRM kind of way. Set the entance to about 50% and the timmers to 40%T, 55%M and 65%B.
- mdroberts1243
Heisthl,heisthl wrote:For those of you that "paint by numbers" there is an error in the photos - the bias caps are backwards (aaaaargh!!!!) luckily I caught this before I powered it on. With no tweaking at all this thing sounds amazing - good enough to post the schematic as built. It has a much fuller clean tone (read hotter) and the OD is very respectable (maybe a touch bright, but not annoyingly so) until you hit the boost and then its incredible, in a very non-HRM kind of way. Set the entance to about 50% and the timmers to 40%T, 55%M and 65%B.
Did you try the 0.01 coupler into the HRM yet?
Any comments on the difference with/without?
Thanks,
-mark.
My tube blog & link directory: http://tubenexus.com
Cause & Effect Pedals FET Dream and Dumble Style Chassis
- mdroberts1243
In the schematic you show the NFB resistor coming off of the 4 ohm tap... I understood that this should change to 8 ohm when you go for 100k???
Your Bias supply is different than others I've seen... was more range required? Or is the transformer tap a different voltage?
Thanks,
Thanks,
-mark.
NFB is off of 4 ohm tap in the BM. Using the 8 ohm tap can tame a 50 watt BM build... This is a 100 watter.
mdroberts1243 wrote:In the schematic you show the NFB resistor coming off of the 4 ohm tap... I understood that this should change to 8 ohm when you go for 100k???
Thanks,
I didn't try a cap there, as I said the HRM is maybe as touch bright and this would only emphasize that.mdroberts1243 wrote: Heisthl,
Thanks,
I wanted the extra gain so I used the 4 ohm tap for presence (many Marshalls do this). The bias is HAD's more modern design - 47uf as a first filter and another 47uf on the trim output. He used 3k9 feed with 24k trimmer tail, I used 3k3/27k.mdroberts1243 wrote: In the schematic you show the NFB resistor coming off of the 4 ohm tap... I understood that this should change to 8 ohm when you go for 100k???
You used the 47pf on the low gain network. I don't think it is there in the BM.... Try removing.
I tried that in one of my builds. Hated it. IMMEDIATELY went back to no cap feeding the HRM stack. It made it thin, shrill, and harsh. Like a bad distortion pedal.mdroberts1243 wrote:Did you try the 0.01 coupler into the HRM yet?
Thanks,
Me: Just one more...
15 differencies + wiring differencies on the preamp section only comparing to my HRM BM build
Heisthl, how much is Your B+1 ?
mat
441mat wrote:15 differencies + wiring differencies on the preamp section only comparing to my HRM BM build![]()
I have 485 on my build. I might try another PT for the fun. I noticed on Your schem that You have 177 on the V1a plate. Is it something to shoot for on this kind of schem ?heisthl wrote:441mat wrote:15 differencies + wiring differencies on the preamp section only comparing to my HRM BM build![]()
mat
