dehughes wrote:Mark and Ron, thanks so much. So, being as my amp mostly just squeals with certain preamp tubes, and only when the preamp gain is MAXED, then I don't have a NFB issue, correct? Plus, my amp is basically an AC30 circuit, and that doesn't use NFB, right?
Then, I most likely have an issue with some wires in the preamp being a bit too close or running together in the wrong way, right? That I can check, by poking and prodding with a chopstick and seeing when the squeal goes away. The only trick figuring out how to get constant signal to my amp while I poke, so I can hear it if/when the squealing stops. Maybe hook up a CD player?
THANK YOU!!!
No NFB, no positive feedback problem that can be solved by swapping output tube wires - correct. Does it only happen when you play guitar? Many amps will squeal without any guitar signal - the noise in the circuit is enough to set it off. If it only happens when you play, it may be microphonics in the tubes. A classic car repair problem is replacing a bad part with a new, but bad out of the box, replacement. Then the problem still occurs, and you're lead to think that the part you replaced wasn't the problem. You'd need a known good non-microphonic tube to rule out that possibility. There can also be microphonics generated around the socket. EF86 tubes are more subject to that problem - a wire between the board and the socket can vibrate enough to set off microphonics in the tube.
