New Problem now that I can hear it, the amp plays like it is a 2 watt amp. I know it's louder than this. I am wondering if the place where I pulled the signal was the right place? Or V1 tube is pulling a lot of current for some reason (191V node with 100kR and 11V on the plate means 180V drop = 1.8mA). I swapped it but no change. I wonder if I need to reduce the plate Ra to get the voltage higher to make it louder?
I pulled the signal between the wiper of Vol pot and pin 2 of V1b
[img
Voltages:
B+Rail:
VAC, 121.5, 122
HT, 253, 315
B+, 283, 352
C2, 233, 288
C3, 152.2, 187
Tube Recto:
5Y3-GT, Low, High
Pin2, 283, 353
Pin4, 141, 180
Pin6, 114, 143
Pin8, 283, 353
12ax7
Pin 1, 93, 117
Pin 2, 0, 0
Pin 3, 0.9, 1.04
Pin 6, 10.2, 11.5 (seems really low)
Pin 7, 5.34, 6.6 (coupled to return stage plate @ FX)
Pin 8, 4.4, 5.4
FX Loop 12ax7:
Pin 1, 5.34, 6.6
Pin 2 mV, -366, -342
Pin 3 mV, 127, 131
Pin 6, 146, 175
Pin 7, 3.37, 5.2
Pin 8, 8.72, 13.8
EL34:
Pin 1, 16.07, 20.1
Pin 2, 16.07, 20.1
Pin 3, 280.6, 348
Pin 4, 230.5, 285
Pin 5 mV, 5.3, 7.4
Pin 6, 232, 288
Pin 7, 16.11, 20.1
Pin 8, 16.07, 20.1
