Moderators: pompeiisneaks , Colossal
BobbySkidz
Posts: 4 Joined: Sun Apr 22, 2012 4:12 pm
Post
by BobbySkidz » Fri Jul 05, 2013 11:29 am
I am trying to find a replacement power transformer for Kustom "The Defender" 50w 1x12 amp.
I can get one from the manufacturer for $80 but would prefer to find a more readily available replacement if at all possible.
Made by a chinese manufacturer named NRE, the transformer is 120v, has 4 primary leads and 7 secondary leads.
A picture of the power transformer label can be found here [img:800:600]
http://i61.photobucket.com/albums/h61/S ... dbdf09.jpg [/img]
Any suggestions would be appreciated.
Bob Stamp
Prairie Dawg
Posts: 156 Joined: Sun Jan 10, 2010 2:19 am
Post
by Prairie Dawg » Fri Jul 05, 2013 1:39 pm
Doubtful. What sort of real estate does it occupy?
I note that one side of the HV winding and the 6.3v winding are marked 0. Does that mean that leg is grounded?
If you believe in coincidence you're not looking close enough-Joe leaphorn
ToneMerc
Posts: 3479 Joined: Sun Apr 26, 2009 3:55 pm
Post
by ToneMerc » Fri Jul 05, 2013 2:46 pm
You are going to be hard pressed to find a drop in "readily available" replacement as the configuration is not off the shelf common. I'm not sure how much money you are willing to put in, but Heyboer could most likely wind you a replacement.
good luck
TM
Cygnus X1
Posts: 913 Joined: Tue Apr 22, 2008 5:56 am
Post
by Cygnus X1 » Fri Jul 05, 2013 3:03 pm
$80.00 is a bargain.
ToneMerc
Post
by ToneMerc » Fri Jul 05, 2013 3:20 pm
[quote="Cygnus X1"]$80.00 is a bargain.[/quot
I was thinking the same thing, rspecially if that costs includes shipping.
TM
BobbySkidz
Post
by BobbySkidz » Fri Jul 05, 2013 3:26 pm
Yes - 0 is ground.
The screws are approx. 2in x 2.5in. slightly larger by 1 or 2 16ths.
On the primary side black and brown are connected together as are the white and blue.
I am not as much concerned about the $80 as I am about getting another cheap Chinese transformer. I'd like to find a better replacement.
Thanks for the help.
At least I know the voltages are not standard.
Bob Stamp
