Tapping for Bias supply - FWBR
Hi All,
If I use a full bridge rectifier with the transformer listed below, how would I configure the bias supply for the two EL34's?
Here are my power transformer specs:
Blue = 6.3 VAC
Blue = 6.3 VAC
Yellow=5 VAC
Yellow=5 VAC
Red=330VAC
Red w/Blue Stripe=0
Red=330VAC
Decko
Blue = 6.3 VAC
Blue = 6.3 VAC
Yellow=5 VAC
Yellow=5 VAC
Red=330VAC
Red w/Blue Stripe=0
Red=330VAC
Decko
Re: Tapping for Bias supply - FWBR
See http://en.wikipedia.org/wiki/Rectifier# ... tification
I think you intend a full wave rectifier, rather than a full wave bridge.
See http://www.webphix.com/schematic%20heav ... II_50w.pdf
for an example of how to derive a bias supply from such a transformer.
Pete
Pete
This is a good example of an adjustable fixed bias circuit, and a nice clean easy to read drawing, too.
http://www.webphix.com/schematic%20heav ... w_1987.pdf
You may have to fiddle with the resistor values to get the bias voltage in the relevant range. The 15K/47K+25K divider is pretty standard. If the range isn't right, I'd swap the 220K for anything from about 150K to 270K depending on what you see. The bias supply draws very little current, so small changes often give big results.
post
Hi Gents,
Thanks for your response!
I wanted to try a full wave bridge rectifier with a choke.
Is this transformer not capable of providing both full wave bridge rectification and a fixed bias circuit from the 350 VAC secondaries?
Blue = 6.3 VAC
Blue = 6.3 VAC
Yellow=5 VAC
Yellow=5 VAC
Red=330VAC
Red w/Blue Stripe=0
Red=330VAC
In looking at the schematic, FWBR requires grounding one point of the diode daisy chain where B+ voltage comes off the opposite side.
Full wave diode rectification (FWDR) B+ off the diodes and ground off the center tap.
Problem with my current transformer is that I do not have additional (Bias Winding)48 VAC taps to power the fixed bias circuit.
That said, I wanted to understand how I might create the fixed bias circuit using the 350 VAC secondaries while still running a Full Wave Bridge Rectifier.
Is this requirement beyond the capability of this transformer?
Please advise.
Decko
Blue = 6.3 VAC
Blue = 6.3 VAC
Yellow=5 VAC
Yellow=5 VAC
Red=330VAC
Red w/Blue Stripe=0
Red=330VAC
Please advise.
Decko
A bias supply doesn't draw much current, so if the transformer is up to your intended tube complement it won't make a difference.
- JazzGuitarGimp
If you're using a four-diode full wave bridge, there is no way to get a ground reference for the minus supply without shorting (and destroying) the PT.
Lou Rossi Designs
and Schematic Capture
here
Hi Lou,
Well, after some digging, I found this link:
http://ampgarage.com/forum/viewtopic.ph ... highlight=
Might be more trouble than it is worth.
Perhaps I stay with full wave rectifier with choke.
Decko
Decko
- JazzGuitarGimp
Re: here
Okay, there IS a way to do it... Just a bit involved.Decko wrote:Hi Lou,
Decko
Lou Rossi Designs
Why do you want to use a full wave bridge rectifier?
With the whole B+ winding that would result in nearly 1000Vdc.
With half the winding you'll get nearly 500V but may require a higher current rating on the transformer, as the Iac = 1.414 x Idc.
If may be helpful to others and beneficial to yourself (due to better responses) for you to provide more detail, eg what are you hoping to achieve?
Pete
Pete
Re: here
Full wave rectifier it and just hang a bias supply off of one of the HT 330V legs.Decko wrote:Hi Lou,
Decko
HT winding>180k> diode>10uf>15k>10uf>47k>25k pot to ground
TM
