I recently had a Super Reverb (Drip Edge) that had a strange issue, it would give you an octave down note when you would play on the low E between the 5th and 12th frets. Really pronounced effect. I found a .022 ceramic cap that would cause it and I replaced it. Well, the amp came back doing the same thing again.... I have no idea where in the circuit it is coming in. I got my signal generator fixed, so I will scope it tomorrow evening, but any tips would be greatly appreciated.
Blue Box is back! Need help
fusionbear
Learning to learn...
- Milkmansound
Re: Blue Box is back! Need help
check the 470R in the phase inverter.
If sit the chassis outside the cabinet on a pillow or something does the issue still take place?
At first I was going to suggest it was a bad guitar string but since the owner experienced it too ...
Combo amp?
Sympathetic vibrations?
If it is the circuit, Milkman might have nailed it.
Could be a phasing issue at that frequency range.
Please let us know what it was.
Combo amp?
Power tube swap? I've got a pair of Sovtek EL84's that do something like what you describe.
fusionbear
lead dress!!! Doh! The feeds to the power tubes were too long and looped back close to the PI. I cut about two inches off and re-routed. Viola! No more blue box...
