Bias drifting LOW!
TooManyProjects
Bias drifting LOW!
Post by TooManyProjects »
Hey everyone! I have an amp that I built a about a year ago. It's something like a deluxe reverb with a lead channel. I haven't had any issues with it lately, but the bias is suddenly way off. Normally, I keep it set to around 20mA. Yesterday, I checked the bias because it had been a while, and it measured at 16mA. I was using a cheap meter because my good one was elsewhere, so I figured the meter just wasn't giving me a good reading. I made sure nothing was red plating and it still sounded good so I left it alone. Today I turned it on and I noticed that every note was crackling as it died out. I checked the bias again and measured only 3mA! Just to be sure I didn't have a supply issue, I double checked the HT, which was around 425V (probably a little low because of the bias) and the bias supply was somewhere around 38V. If I had a leaky coupling capacitor off of the phase inverter, it would always cause the bias to be HIGH, right? What could be causing this?
Re: Bias drifting LOW!
I would suspect the power tubes first. But first, pull them out, and measure your plate and bias voltages with no power tube to make sure they're in order.
TooManyProjects
Okay, xtian. I just pulled the power tubes and measured the plate voltage @ 430V and the bias supply voltage at -49.2V. The bias voltage at the grid load resistors was -39.9V, if that matters. I have some new tubes on order.
Can you clear up your reading at TP22? Put the power tubes back in and measure. That's where you should see ~0.040v DC, indicating that the bias current thru the power tubes is set correctly.
TooManyProjects
What's TP22? Do you mean the power tube grid?
It's on the schematic--it's the cathode of the power tubes. Basically, you're measuring DC voltage drop across that 1-ohm resistor.
TooManyProjects
Ah. I should clarify that this is NOT a Deluxe reverb. It is a scratch build that uses a DR transformer set. In this case, there is a separate 1 ohm resistor for each cathode. So, yes. Normally I would be seeing around 20 mV drop per tube (40 if the PT cathodes used a shared resistor). As I mentioned in the original post, I measured 16 mA of cathode current the first day, which was a bit low but I assumed I was getting a bad reading because it was a cheap meter. The next day it was all the way down at 3mA. This reminds me: I'm not sure if I measured both tubes or just one. I think they both measured low but I'll have to double check.
Strike one! Ok, snuck that one past me. No second chance.
TooManyProjects
Here's the schematic, in case you're interested. I forgot to draw the FS jack and the filament fuse. There is also currently a switch to defeat the negative feedback. Not sure if I'm going to keep that feature. Other than that, I think the schematic is accurate.
TooManyProjects
Okay. Forget what I said. Turns out there were several errors. Here's an updated one.
TooManyProjects
Just installed the new tubes and they biased just fine. Everything is good now. Thanks!
