The reverb signal grounding can be really fussy and easily creates ground loops depending on the grounding scheme of the tank. Ya know, If the cap isn't the issue.BobL wrote: ↑Wed Apr 21, 2021 6:15 pmOh, hey, thanks! We got a whole record of that stuff out there.pullshocks wrote: ↑Wed Apr 21, 2021 5:48 pmHey Bob, I just watched "Raven Lee" on your web site. Great stuff!!!BobL wrote: ↑Wed Apr 21, 2021 4:57 pm Moving the ground for the balance pot waaaay down to the end w/ the preamp ground does seem to have gotten rid of the bad hum... but also introduced a far more irritating oscillating click and static...
I have the power amp grounded to the same lug as the CT for the PT primary - is this a bad idea?
Using a chopstick to move the input wire around has no impact on this noise - changing the balance pot value impacts overall noise, but doesn't remove it.
Here is the noise: http://www.boblefevremusic.com/temp/mon ... lation.m4a
That new noise sounds awful. I've pretty much lost track of your layout and ground system, maybe post a current gut shot? Did you bring the PI balance pot ground to the negative terminal of the Node C filter cap? If not try that.Bass player in that video died about a month ago, so it's been rough going lately.
I moved the 68K resistor on the input to the tube lug... seems to have changed some things but not improved things...
The balance pot ground I took all the way down to the preamp lug, but I can try it on node C as well.
What is very interesting is that the buzz (sounds like 120 to me now) is *very* dependent on if the amp is upright or not. I leaned it forward to chopstick some stuff and it reduces greatly (and yeah, I followed with my ear to make sure it wasn't just that I couldn't hear it as well).
It also seems to be very influenced by the reverb circuit - if the tank is plugged in, the oscillation is mostly gone, but the buzz is *bad* now.
If I move the wire going from the reverb pot to the volume pot, it significantly impacts the buzz. If I turn up the reverb knob, it significantly impacts the buzz. If I remove the reverb tube, the oscillation starts to come back, especially with the amp tilted at about 30 degrees...
I had a similar issue in the first amp I built, a JTM45, and it turned out to be a bad capacitor that only was bad when the amp was upright (it was a pain to chase down!)
I had a similar oscillation pop up a while back when I was trying different caps in the reverb circuit, so now I'm thinking there is a very strong chance that the issue is with the .1uF cap I put in there. I'm going to replace that cap and see what happens.
Mike
