Hello,
I can't seem to solve the bias drift issue on my JCM 2000 DSL100.
The amp is a 1998 model. Main board JCM2-60-02 Issue 5. Schematic: https://www.drtube.com/schematics/marsh ... 20iss5.pdf
The things already done to remedy the problem:
Everything in this post : http://www.hullerum.de/Marshall/TSL122repair.html
Drilled pin5 on the power tubes, replaced the resistors.
Changed the PI coupling capacitors.
Made a direct line from the PI coupling caps to power tube resistors, destroyed the old traces.
New power tubes.
The standby ON/OFF test without the tubes installed is ok, voltage readings remain stable ( -45V / -44.8V ).
The odd thing is that the bias rermains rock solid with no PI tube installed ( changed the PI tube also ).
After i put the PI tube in the bias starts to drift. Right side way more than the left.
Any suggestions at where to look next would be greatly apreciated.
Ty.
JCM2000 DSL100 bias drift issue
Re: JCM2000 DSL100 bias drift issue
Hi,
Try lifting the newly fitted PI caps from the bias side up in the air.
Run wires directly over to the O/P tube grid resistors.
Not pretty but it will ensure that there is no longer any contact with the PC board on the bias side. I found that there mustn't be any contact with the PCB on the bias/grid side
Just my 0.02cents worth.
John
John
amp is disaster. it must be thrown in the trash. or remove all motherboard and rebuild one good JCM800 from it, using only transformers. i quit from repairing this
That's a real mess. Apparently it can be made to work by hacking up the original board, but life is too short. Marshall dealers can supply a replacement board with improved material and components, which is a better fix in the long run, IMO: https://www.tubesandmore.com/products/b ... 00-dsl-100
