Like Sluckey said, Idle and Full Output do not vary much with Cathode Biasing.stephen_w_keller wrote: ↑Mon Jun 01, 2026 4:18 am I'm guessing that 73mA on the plates is the no-signal bias. This looks like a class AB push-pull stage. I reckon it's going pull a lot more current when driven to full-signal levels.
Two real world examples from my data:
Cathode Biased Amp w/ 6L6GBs and 5U4GB Rectifier: Idle dissipation of 95%, HT Current at Idle 139mA, Full Clean Output 156mA, +17mA, Increase 12% (nearly 8mA of the increase was additional screen current)
Fixed Biased Amp w/ 6973s and 6CA4 Rectifier: Idle dissipation of 60%, HT Current at Idle 63mA, Full Clean Output 110mA, +47mA, Increase 75%
As you can see, the Cathode Biased amp does increase some but just 12%, where the Fixed Bias amp increases by a much greater amount at 75%.
Given this Cathode Biased example applied to the OPs Harmony: 73mA Idle current +12% = 82mA which leaves 18mA for the Preamp which is plenty for one 6AU6 and two 12AX7s.
