Single-Parallel-Single switch to amp input
Re: Single-Parallel-Single switch to amp input
Hi Harry,
I am building a Mark Huss 6V6 Plexi. I originally had planned to incorporate such a switch in my amp but ultimately decided against it, though I still think it would be quite interesting to hear the differences in tone. Anyway, I ran the idea by the experienced builders on ppwatt.com and was told that while it was possible to do, much of the magic in the Plexi was to be found in blending both channels. I also wanted to incorporate a Parallel/Cascade switch. So, to get both channel switching and the Plexi/2204 mod to work correctly, the switching scheme would get more complex. Since I would probably just end up running it with both channels most, if not all, of the time, it seemed like a lot of complexity for something that might go largely unused. I ended up skipping it and using one input jack, I jumpered the Bright and Dark channels permanently, and just went with the cascade switch instead. Would there be any difference between a channel select switch and just turning the volume down for each channel?
I'm certainly not try to convince you one way or another, just pointing out my own experiences. I've attached a drawing I made when I was thinking about it. Perhaps it will be of some use to you. My skills are pretty basic and somewhat limited so perhaps there is a more efficient way to do it. That's just what I came up with
:); the design is unproven. Oh, and for the grid resistors, I show 10k but you can use whatever you deem appropriate. On my build I do have a switch that selects between 34k (68k + 68k) and direct (no resistor) input.
For the switch in the drawing, check out Mouser:
http://www.mouser.com/search/ProductDet ... M202401-RO
If you do go for it, please report back as I would be very interested to know how you did it and what it sounded like and all that.
Colossal
![Embarassed :oops:](./images/smilies/icon_redface.gif)
Colossal
Harry,
I'm glad it was of use. I too like the idea of switching options just to satisfy my tonal curiosity and experimental nature. My amp has a number of switches to change voicing, bright, fat, cascade, etc. A lot of this interest comes from my lack of experience so I wanted to have a platform that at its root sounds killer, but has some flexibility built into it. Along the way I've seemed to find that the best amps and ampbuilders select for simpler models (!) so I reign myself in by saying, "well, if [a certain mod] was worth it, it would have already been standard on these great amplifiers":lol:. But yes, I suppose if you wanted to have as many possible tones the channel switching option could be quite interesting. Maybe others here can add something? I also incorporated a VVR2 into my 6V6 Plexi, will post some build photos soon. By the way, I've seen your site before. Your amps look and sound great!
Colossal
Colossal
Hey guys!
Here is maybe another way to skin a cat. This way you ground the input of the unused channel and save two resistors.
Colossal, your drawing was so good that I took the liberty to use that as template in my example. I hope you don't mind.
Ville
Ville
You can also have three input jacks, with the third being "both." Here is an example of how it can be wired (just ignore all that Hiwatt stuff to the right
http://mhuss.com/Hiwatt/Schematics/DR_P ... put_v1.pdf
FWIW, I always use 'both' nowadays.
--mark
--mark
No, I don't mind at all, and your method is far simpler! I knew there was a better way. Like I said...beginners mind...villems wrote:Hey guys!
Ville
Before I was into amp building, a budding builder with massive electronics industry technical chops wanted to do the same thing. I was his guinea pig (for a significantly reduced price). A couple prototypes and 5 months later he decied to throw in the towel. Ended up just doing two entirely separate preamps; signal split at the input and rejoined going into the PI.
Having said that, I'd still give it a whirl. He is an extromophile when it comes to hum, so you might get there with an aceptable noise floor for you. He hasn't built any TWs. I thought of turning him on to them, but decided it might push him over the edge. LOL.
Check out the Mystique Amps "Blue Star". It takes a different approach for a similar effect. Both channel's are hardwired in parallel, one input with independant volumes. The voicing is tweaked for greater differentiation between the two channels, and the more gainy one can grounded out via a footswitchable relay for "channel switching". It's a nice sounding amp. If you google it, you'll find soundclips on someone's personal webpage.
"In this world you will find hardship and trials; but take heart, for I have conqured the world."
John 16:33
John 16:33
Hello,
Could you build it with two inputs and then use an A/B/Y pedal to choose between the three channel modes?
Here's an example a quick search turned up. http://www.morleypedals.com/abyes.pdf
dave
dave
When I build a Plexi I normally just wire a piece of shielded cable from 1 input jack over to the first 12AX7 and connect it to the junction of 2 resistors ( 33Ks make the most sense, but I have used 68Ks before I really thought about it and that worked fine too.) each of which goes to the grid of the first stage of each channel. This way the channels are always jumpered and the signal path is shorter than using a patch cable.
Just for fun I built this amp :
http://www.classictubeamps.com/6v6plexi.html with 2 switches on the rear panel that allow you to turn each channel on or off, but my conclusion is that there is no difference in sound between flipping the switch or just turning the volume knob all of the way down for the channel you don't want to be on.
Hope that helps.
Hope that helps.
Colossal wrote: I ended up skipping it and using one input jack, I jumpered the Bright and Dark channels permanently, and just went with the cascade switch instead. Would there be any difference between a channel select switch and just turning the volume down for each channel?
KT66 wrote: Just for fun I built this amp :
http://www.classictubeamps.com/6v6plexi.html with 2 switches on the rear panel that allow you to turn each channel on or off, but my conclusion is that there is <b>no difference in sound between flipping the switch or just turning the volume knob all of the way down for the channel you don't want to be on.</b>
Hope that helps.
