I am considering putting a single Celestion G12 Century Vintage speaker in my Blues Deluxe Reissue. I'm sure I read somewhere that you're supposed to ensure that the speaker is rated at double what your amp is, is this true?
Would this speaker be okay in my amp? I never get the volume above 4 or 5 anyway, so would I be safe running it or would I still risk damage to the speaker/amp?
60W speaker in 40W amp??
Re: 60W speaker in 40W amp??
That rule of thumb is just that, not hard and fast. 60w for a 40w amp is probably more than adequate. The thing is, sometimes, if pushed hard, you might actually get more than 40w out of the amp. It depends on the amp. In your case, I wouldn't think twice. I don't think I'd put a 40w speaker in a 40w amp.
- Jammin'John
Pound
If you hit it hard with pedals a lot or use humbuckers and turn it WAY up all the time you may blow it.
That said,it's probably not an issue.
JJ
JJ
Let's ride/Let's Jam
- Scumback Speakers
My first amp client bought a dual 6V6 amp from me. My amp builder (at that time) rated it at 10.8 watts RMS at 2 on the volume knob. 15 watts at 5, and around 19 on 8, although the volume dial went to 10.
The client had me recone an old G12-65 to 30 watt specs for him from the local Celestion dealer.
13 months later (and one month out of warranty) the speaker fried.
Not all amps are created equal in terms of volume, drive, gain, etc. This client found that an amp with a single 12AX7, two JJ 6V6's and one 5AR4 rectifier could kill a 30 watt speaker in 13 months.
He ran that amp at 5-6 on the volume knob and didn't use pedals. So some amps vary in their power output. You might want to have your amp measured for it's true power output at the volume you run it at. The 60 watt speaker might be fine... or not.
There are two most common ways to destroy a speaker. (Well, besides doing your Pete Townshend impression and stabbing the guitar into it!)
1. Damage the voice coil by running too much power (=heat) through it.
2. Damage the cone/spider by over exercising the speaker--forcing it to go beyond its excursion limits. (This is why putting a Celestion V30 in a ported cab is a no-no.)
Amps with negative feedback more effectively damp speaker excursion than do those without. For example, if you were to clip out the NFB resistor on a Twin Reverb, you'd probably shred the speakers in pretty short order.
Over-filtered guitar amps that produce too much bass can tear up the cone/surrounds, as well.
FWIW, hempcones seem to be stronger than tree paper cones, but their tone ain't for everybody.
At the end of the day, it's about making an appropriate match between the amp's personality and the speaker and the application. In amps that are destined to be cranked for extended periods, overmatching the power rating is a good idea.
Rich Gordon
www.myspace.com/bigboyamplifiers
"The takers get the honey, the givers get the blues." --Robin Trower
- Jammin'John
Double
Most times I pick a speaker that is rated for twice the output of my amp.
Though I'm runnin' a 30w weber in a Brown Deluxe.
A large magnet can help to control a low watt speaker and keep it together.
My most extreme example of this is a Weber 15w Blue with an 80 oz. magnet with a neo helper.
It's in a 5E3 and it is LOUD !
JJ
JJ
- Jammin'John
Double
JJ
JJ
- Luthierwnc
You also have to consider the sweet spot for the speaker. Some sound best when they are on the verge of blowing up. Others are best when they aren't breaking a sweat. I've had better luck with Celestions as part of a set than singles.
FWIW, lately I've been leaning more towards speakers that can handle a lot of juice -- mostly because the amps I make get pretty raunchy when they are pushed and I don't want the speakers to have opinions of their own.
YMMV, Skip
YMMV, Skip
First things first, fire the amp builder. ANY builder/designer of an amplifier that would spec an amp that way has no business building amps. Even if he was making any logical sense at all, spec'ing power based on preamp gain setting without regard to input signal level and EQ, he still used a linear pot as volume pot instead of a log or audio taper. Gain settings have nothing to do with output power.Southbay Ampworks wrote:My first amp client bought a dual 6V6 amp from me. My amp builder (at that time) rated it at 10.8 watts RMS at 2 on the volume knob. 15 watts at 5, and around 19 on 8, although the volume dial went to 10..
Did you dissect the VC to see what was the mechanism of fault? Was it heat or mechanical failure?Southbay Ampworks wrote: The client had me recone an old G12-65 to 30 watt specs for him from the local Celestion dealer.
Not all amps are created equal in terms of volume, drive, gain, etc. This client found that an amp with a single 12AX7, two JJ 6V6's and one 5AR4 rectifier could kill a 30 watt speaker in 13 months..
Possibly the speaker was not really capable of handling 30watts of sustained power.
Backtracking: Speakers power is based on heat dissipation and expressed in RMS power which is dependent on the wave form used in the measurement. In actual use, a voice coil can subjected to RMS power in excess of what the amp is rated at. An amp is measured using a sine wave which has a very predictable relationship to peak voltage. An amp in a distortion mode can have a much higher duty cycle than a sine wave so it can generate more heat in the VC than a sine wave of the same peak voltage. A True RMS measurement calculates the heating power of a wave form as related to steady state potential( DC) of the same numerical value. 1 volt AC RMS applied to a purely resistive heating element, will heat water to the same level as 1 volt DC.
An amp with voltage limiting of say, 1 volt peak will generate different heating potential depending on the duty cycle of the waveform. This can range from short high speed rise time pulses generating .001 watts at the same 1 volt peak voltage as a fully saturated Square wave generating 1 watt of heat into the same load.
So amps are rated via sine waves, and speakers are rated in total heat dissipation which to make any sense in real world applications, would require rethinking how amps and speakers should be rated. Until then, the whole issue of matching speaker ratings to amp ratings an apple to oranges relationship.
A square wave amp measurement rating would make more sense that could be related more realistically to dissipation ratings of speakers, that would represent a realistic worst case value. Worst case is the rating needed for heavily distorted harmonically rich wave forms as seen in all guitar amps when pushed.
Given all of the above, no rule of thumb quite fits. It depends on style of play, thermal limits of the speaker voice coil and and duty cycle of the waveform.
When we design powered speakers, none of these ratings are worried about, neither is impedance since it is a closed system. A combo guitar amp should have had all the variables considered by the engineer and power ratings don't mean much. Just SPL out before sounding like crap. If the acoustic power of a combo is 10 watts( a high value of sound energy), it makes no difference whether it is 50 watts RMS generated by the amp feeding an efficient speaker/cabinet system or 1,000 watt amp feeding a high power, low efficiency speaker. The SPL could very well be the same.
High power drivers are usually low effeceincy due to higher mass of the cone and VC wire diameter, but most important is the wider magnet pole piece gap needed for clearance of a less precisely controlled postion of the more massive VC.
In other words, large amps do not necessarily mean high SPL. To make a speaker survive the mega amps available, speakers keep getting less and less efficient, which in turn, makes their minimum power requirements to get anything out of them keep rising.
This might give a false sense of security, depends how the power is measured and the mechanical/thermal characteristics of the speaker. Again, the settings of the knobs mean nothing to any of this, a hot pickup or some eq settings can easily generate full power at low settings.Southbay Ampworks wrote: He ran that amp at 5-6 on the volume knob and didn't use pedals. So some amps vary in their power output. You might want to have your amp measured for it's true power output at the volume you run it at. The 60 watt speaker might be fine... or not.
