Hi all,
Was working on a Bad Cat Cub ii for a friend that had a pair of hosed EL84's.
Tubes were replaced and all is working fine, puts out about 15 - 16 watts into 8 ohms. Along the way I checked the OT primary P to P impedance (just for future reference) and found it to be ~4K (3.96K Measured) into 8 ohms. It in fact measured allot like many AC30 OT's I have documented over the years.
Of course I was expecting more like 8K P to P impedance so I have double and triple checked. I have checked both the 4 ohm and 8 ohm tap and used a couple of different methods and still come out to a turns ratio around 22.2:1 with the Impedance switch set to 8 ohms.
Anyone else run across this? Or does anyone have a Cub ii they would be willing to check?
The transformer is stamped TDS 1165 and the output taps are as follows:
BLK- Com
Orn - 4 ohm
Grn - 8 Ohm
Light Blue - 16 ohm (not used)
Any info would be appreciated......
Thanks,
-Brad
Bad Cat Cub ii OT Question
Re: Bad Cat Cub ii OT Question
I am just thinking to start a Matchless Lightning 15 project and faced the same question concerning OT impedance. Lightning is a derivate of Vox AC15 and I think that this BadCat is the same origin. I seeked information from net and come to conclusion that this OT should really be 4 kohm. Many people say that Lightning is a very good sounding amp and I am wondering if one part of that sound is so called OT mismatch. Harry
Matchless underloads all their amps, it's almost a Matchless trademark. Mentally I sort Matchless and Bad Cat into the same category. I like correctly loaded outputs but I must admit that stressed EL84 tone is cool, too.
It comes down to tone. If you like how it sounds (and you can stand a little shorter tube life) leave it alone. If you don't like the tone then off you go on a quest for an OT that results in the correct load and has a tone you like.
Thanks Guy's, much appreciate the input!
I think your right.
Got ‘a say I really liked the way it was sounding......and yea it is very much like looking at a Matchless chassis on the inside.
I talked to James at Bad Cat, said he did not know off the top of his head what the primary P to P Z of the OT was but did say the EL84's are "run hot" in that amp.
I think my friend needs to be prepared to keep EL84 pairs on hand.
BTW anyone know who manufactures the transformers for Bad Cat?
Thanks again.....
-Brad
I think your right.
Thanks again.....
-Brad
TDS - Transformer design and supply:bfrederi wrote:.
Thanks again.....
-Brad
http://transformerdesignandsupply.com/
They do all the matchless stuff too. Before buying westlabs stuff, consider TDS, they're exactly the same but cheaper.
Thanks daz.... appreciate the info
Have you had anything custom wound by TDS?
