Phil_S wrote:Here's the cold truth as I see it, no sugar coating. It's a damn shame you replaced all those caps and resistors. You just devalued that amp significantly and produced no result. There was no reason to do that work. You are shooting in the dark rather than concentrating on the most apparent problem, which is lack of bias voltage.
Ah well, it's your amp, so you do as you see fit. If it were mine, I'd figure out the bias voltage problem. It well could be that is the only problem, so concentrate, don't go all over the lot. The bias problem isn't hard to solve. When you tap the HV winding for bias voltage for bias, the only difference required is a dropping resistor, instead of 470 ohms, needs to be in the 150K to 270K range depending on what the PT is generating. I'm thinking you need 180K or 220K to get it to the mid 40's. Make sure everything else in the bias circuit works as it should.
BTW, I think you mis-heard them at Hammond. Hammond is now making a drop in replacement for a Fender, not the other way 'round. I seriously doubt Fender is winding it's own.
I understand, agree and appreciate all of your comments Phil...
I kept all the old parts in a bag.
Resistors were out of values anyway...
I only changed the ceramic caps for silver mica.
It's not has if i butchered the amp. I can easily put them back in if a collector is eventually buying it...
I got the bias under control now...
The Hammond 273X is a very old one with the Hammond metal badge on it. It will go in my parts bin...
I will bring this amp to the repair dude.
I asked Steve twice after he told me that Fender was building these trannies for them...Fender is building these trannies for you?
Either it's true or Steve shoots the shit...
One thing i know for shure...i know i'm not worthy!
My bench will be dismantle today and stored for better days...
I better concentrate on me playing...
