My bad, I meant the device was your MOV, with the 1M5s outI'm not clear on what you mean by MOV's out in the 2:55 - 3:17 section, though... What is performing the varistor function?
We can conclude that the 1M5 that was across the terminals is not needed, and the effect is marginally better without it.
For sure
That would be my guess, but there is very little range. Say, once it's turned down to "8", it's basically gone. So not only does the effect cease, there's not really any speed range, it's basically on or off, at the highest speed, the one in the clip. I haven't fiddled with the circuit around the speed pot yet, and I have a 1M hacked across the 1M pot, and I haven't looked at the scheme lately, but that would lead me to believe it's supposed to be 500K. So at the least, my taper is screwy.Do you think that turning the speed down causes the oscillator to stop? If so it might take some seconds to restart. And this does not happen when using the NOS varistors?
The NOS have a broader range of speed, and don't take time to restart, or rather the oscillator to restart, if that's the case. The latter obviously isn't a major concern, but interesting.
Absolutely a success! Great work, Martin. You just saved everyone $75-$100 a build.Overall, it sounds like the MOV-Resistor substitute is a viable alternative to the NOS varistors, so we can declare a success here. I do believe I can hear a little richer sound from the NOS parts at the end of the clip, though. There is one more tweak I am considering, which is lowering the lowest voltage MOV to 22V, but that is definitely getting down to fine tuning.
