Benson Monarch
9 others liked this
Re: Benson Monarch
Hey gang...just happened to check back today, we use 22uf on the OT supply, a 1k dropping resistor, 47uf on the screens, and then it goes off to the preamp filtering nodes with larger value resistors (usually 4.7k / 22uf to the PI and then 4.7k / 22uf to the preamp. I find this yields the benefits of a somewhat loose power section while still pinning the screens where I like them, and has the added benefit of allowing less ripple to reach the split plate circuit. BTW that trashy looking amp in the pic someone posted from Premier Guitar was a sloppy job I made for myself that didn't even use the same components as even the early amps, and just happens to be the first thing that comes up when I search for gut shots. Theres a lesson in there somewhere
Re: Benson Monarch
Mike
Re: Benson Monarch
Thanks Chris. So no front-end PI filter. Curious if you're curious about trying it, or did and didn't feel it works.chasbenson wrote: ↑Mon Apr 12, 2021 1:57 am Hey gang...just happened to check back today, we use 22uf on the OT supply, a 1k dropping resistor, 47uf on the screens, and then it goes off to the preamp filtering nodes with larger value resistors (usually 4.7k / 22uf to the PI and then 4.7k / 22uf to the preamp. I find this yields the benefits of a somewhat loose power section while still pinning the screens where I like them, and has the added benefit of allowing less ripple to reach the split plate circuit. BTW that trashy looking amp in the pic someone posted from Premier Guitar was a sloppy job I made for myself that didn't even use the same components as even the early amps, and just happens to be the first thing that comes up when I search for gut shots. Theres a lesson in there somewhere
Best .. Ian
Re: Benson Monarch
Thanks to Chris for posting up that info, and hats off for a fantastic sounding amp.
Based on Chris's post I updated my power supply as shown below, and tried it out for an hour. The amp is really fun to play.
EDIT:
With the power supply change and running my PT 6.3V center tap to the 6V6 cathode connection, the hum issue is gone.
For a permanent build I would add the DC heaters, but it is working very well with the elevated AC heaters.
EDIT:
Re: Benson Monarch
edit, nevermind I read your schem from left to right.
- dorrisant
Re: Benson Monarch
Thank you Chris! You are a gem!!
Re: Benson Monarch
Like a pi filter in front of the OT node? I haven't had reason to incorporate that in the Monarch (since the production ones don’t hum appreciably), but I do enjoy the sound and feel of some series resistance or inductance in the power supply path in other designs. The 5E7 PSU circuit for instance is so wrong but so right.
didit wrote: ↑Mon Apr 12, 2021 11:55 amThanks Chris. So no front-end PI filter. Curious if you're curious about trying it, or did and didn't feel it works.chasbenson wrote: ↑Mon Apr 12, 2021 1:57 am Hey gang...just happened to check back today, we use 22uf on the OT supply, a 1k dropping resistor, 47uf on the screens, and then it goes off to the preamp filtering nodes with larger value resistors (usually 4.7k / 22uf to the PI and then 4.7k / 22uf to the preamp. I find this yields the benefits of a somewhat loose power section while still pinning the screens where I like them, and has the added benefit of allowing less ripple to reach the split plate circuit. BTW that trashy looking amp in the pic someone posted from Premier Guitar was a sloppy job I made for myself that didn't even use the same components as even the early amps, and just happens to be the first thing that comes up when I search for gut shots. Theres a lesson in there somewhere
Best .. Ian
Re: Benson Monarch
Anything that works cannot be so wrong, so you're right. That's one excellent example. Was more so referencing some fairly common use of CRC PI filters in old-school single-ended designs. And also a Gibson GA50 inspired project put together a few years back - https://ampgarage.com/forum/viewtopic.php?t=30164. A 6-8dB ripple reduction at the OT node, to me, seems well worth cost and effort.chasbenson wrote: ↑Tue Apr 13, 2021 6:30 am Like a pi filter in front of the OT node? I haven't had reason to incorporate that in the Monarch (since the production ones don’t hum appreciably), but I do enjoy the sound and feel of some series resistance or inductance in the power supply path in other designs. The 5E7 PSU circuit for instance is so wrong but so right.
Best .. Ian
Re: Benson Monarch
Hum is now GONE!!!
Even with AC heaters, and breadboard construction. Ran the PT 6.3 V center tap to the 6V6 cathode connection.
DC heaters may be even better.
Sorry for any confusion caused by my post yesterday. I will edit accordingly.
Re: Benson Monarch
Help me get a grasp on this... to which side of the 25uF/250r pair did you run this?pullshocks wrote: ↑Tue Apr 13, 2021 6:16 pm Hum is now GONE!!!
As for the filter caps, trying to figure out the best way to get another node onto my board... hrm...
Re: Benson Monarch
Between the tube cathodes and the cathode resistor and cap.
Merlin Blencow has on this page (scroll down to Heater Elevation). http://www.valvewizard.co.uk/heater.html Robrob also shows it on his 5e3 pages.
Re: Benson Monarch
Since the connection from the 0.1uF coupling capacitor goes to pin 7, I think the plate connections need to be reversed like this. (But double check.....
EDIT--Yes you could change the grid connections at the tube socket, but I think it would be easier to change the plate connections as shown.
Re: Benson Monarch
Doing this w/o any other changes did not solve hum, FYI.pullshocks wrote: ↑Tue Apr 13, 2021 9:39 pm Between the tube cathodes and the cathode resistor and cap.
- dorrisant
Re: Benson Monarch
How did you configure your B+ dropping/filter string? Maybe post a pic.BobL wrote: ↑Wed Apr 14, 2021 3:24 pmDoing this w/o any other changes did not solve hum, FYI.pullshocks wrote: ↑Tue Apr 13, 2021 9:39 pm Between the tube cathodes and the cathode resistor and cap.
Re: Benson Monarch
It's as per original schematic and layout, not updated.dorrisant wrote: ↑Wed Apr 14, 2021 5:25 pmHow did you configure your B+ dropping/filter string? Maybe post a pic.BobL wrote: ↑Wed Apr 14, 2021 3:24 pmDoing this w/o any other changes did not solve hum, FYI.pullshocks wrote: ↑Tue Apr 13, 2021 9:39 pm Between the tube cathodes and the cathode resistor and cap.
