These work very well and are easy to install. They are also available in black or white plastic and several different sizes.
https://www.ebay.com/itm/1-4-NPT-Strain ... SwtnpXjU32
Mains connection parts?
Re: Mains connection parts?
...Steve
damn those are cool, I've seen the plastic ones, but a metal one would be very slick.
SoulFetish
a punch is totally the way to go, short of a mill or laser cutter. I wish I had pulled the trigger when rs-online.com sold one for pretty short money. While I love my greenlee punches and ratcheting crimper I have, a single rectangle punches go over $350 when I've priced them out. Unfortunately I haven't been able just justify allocating that kind of cash for a single punch.... yetM Fowler wrote: ↑Mon Apr 06, 2020 4:02 pm Someone gave me crap for spending my money on an rectangle panel punch; however, I don't think they understand how many amps I've built before I purchased that IEC punch.
I don't regret the purchase at all but very expensive.
Before that I used dremel with small disk cutter; or drilled large holes with a nibbler to enlarge then file to smooth; or multiple small holes, use pliers to pull parts off, then file; or drilled several holes to cut out with sabre saw. All of those methods suck.
I also get lazy or for a reason or two have to use a round hole with screw together power cord restraint.
For Fender amps I have a $7.95/free shipping from China restraint pliers that works great.
If you only build one amp or several just use whatever method you can, I understand you don't want to invest in so many tools but I use them in snowmobile repairs, mini bikes, motorcycles, truck, car and my 32 Ford Roadster. Forgot the skid-steer.
Gland w/ nut. Sounds like you would want to get tested after using.
Seriously those look really cool. Dang something else I didn't know I needed.
