Geeking out on computers for a minute: Most generic PC use separate fans for CPU cooling and case exhaust. Dell increased cooling efficiency and reduced cost by using a custom plastic duct so that the CPU fan would take in ambient case air for CPU cooling and directly vent the exhaust out of the case. One fan did two jobs (case ventilation and CPU cooling) instead of mixing retained CPU heat/exhaust with the rest of the air in the box and relying upon a separate case fan to purge it. The custom duct work made these Dell cooling parts pretty much incompatible with any other PC. They started doing this custom duct stuff in the P2/P3 era. That heatsink came from a P4 that used a custom heatsink and blower assembly.
https://dl.dell.com/Manuals/all-product ... _en-us.pdf
P4 cooling systems have a minimum Thermal Design Profile of 50W. That's huge compared to his needs for this amp, if we assume that a really good thermal junction exists between the planar surface of the heatsink and the backside of a mosfet, which isn't always flat.
How much voltage is the mosfet dropping? How much wattage is going to be dissipated in the mosfet under max load? The OP hasn't posted those numbers, but the total wattage can't be all that much, and the heatsink he's using looks like it will amount to a maximum overkill solution. He's looking at a heatsink that has a 50W TDP under ideal conditions. But ...
That TDP rating for the heatsink is based on Dell's use of custom ductwork to direct flow across the fins of the heatsink, to prevent stagnation of air between the fins. So it isn't really clear how efficiently the heatsink will work without ducted air, but I'm guessing that he's got so much surface area available that his fan will be adequate. If not, then adding some DIY ductwork or directly mounting a fan onto the fins could be something to consider. One also has to consider how effective of a thermal junction exists between the back side of the mosfet case and the CPU heatsink.
This is such an off the wall solution that it's interesting. It would be interesting to know how much power he needs to dissipate, and to take heat measurements with the amp dimed into a resistive load to see how efficient this approach turns out to be. Since we're geeking out on this, bcmatt do you have an IR thermometer?
Better tone through mathematics.
