Dead PT...autopsy help requested
johnnyreece
Re: Dead PT...autopsy help requested
Post by johnnyreece »
trobbins wrote: ↑Wed Jul 29, 2026 1:22 am johnnyreece, did you progress the repair?
Sorry for the lack of replies; was on vacation with my in-laws. I have not decided yet whether I'm going to replace the PT with the same one that failed or a different one. So, short answer is, I don't have any updates. I wasn't able to find where the short was, but none of the secondary taps gave any voltage whatsoever.
trobbins wrote: ↑Wed Jul 29, 2026 1:22 amCan you confirm you just tested the rectifier tube on a typical tube tester, as that wouldn't have applied anything like rated PIV or been able to measure leakage current at a reasonable PIV? Were you going to add ss diode protection to the rectifier tube anodes, as a way of avoiding rectifier tube arcing from being a possible fault scenario?
Yes, it was just an Eico 667 I tested with. I suppose I've got a million diodes hanging around, might as well put those in for protection on the next go-round.
trobbins wrote: ↑Wed Jul 29, 2026 1:22 amThere is no bias adjustment - did you measure the bias voltage with the 6K6's and check if idle dissipation was ok and balanced?
The amp uses a shared cathode resistor. Honestly, I don't think about matching too hard. I've never witnessed any red plating, if that helps.
trobbins wrote: ↑Wed Jul 29, 2026 1:22 amDo you have a way to measure mains primary current with a meter? You may want to check what current can be reached, and then check if a lower valued fuse rating is reasonable.
It's very possible. The issue becomes, if I use different power tubes, I would likely need to swap fuse sizes when I swap power tubes. I'm sure it's not that big of a deal to do that, though. What I do to measure primary current is remove the fuse and clip my leads to the two terminals on the fuse holder.
flemingmras wrote: ↑Wed Jul 29, 2026 1:21 pm You say this amp is "made to run a variety of power tubes". Something tells me that you fail to consider the heater current differences (and I doubt any Fender style transformer is going to be wound for the heater current of many of them).
The PT I used (link in above text) is suitable for 200mA HV, 6.3V @ 6A, 5V @ 3A. So, let's round up to 1A for all three preamp (2x12AX7 and 1x6SL7), that leaves 5A for the pair of power tubes. As the amp failed while running the most power-sipping filament tubes I have, I would hesitate to say that was the reason for the failure, but hey, I'm sure stranger things have happened.
flemingmras wrote: ↑Wed Jul 29, 2026 1:21 pmWhat output transformer are you using? These tubes also have very different load expectations.
Weber 6M45 (their version of a JTM45) OT: https://www.tedweber.com/wot45/. Long story short, it's a 6k8 Primary. So, sometimes I look at it as half or double, depending on what tube I'm using. For KT66 and 6V6, I set the output as if it's 6k8. For 6L6 and EL34, it's 3k4. For 6K6, 13k6. For example, on the green tap, that would be a 4 ohm load for a 3k4 primary (6L6, EL34). However, the same setting would be a 8 ohm load for 6k8 (KT66, 6V6) or a 16 ohm load for 13k6 (close enough for 6K6). I've attached a picture showing the data sheet for the OT and how my selector switch label is laid out on my faceplate.
