Will measure tonight, but no they dont look burnedmartin manning wrote: ↑Wed Sep 16, 2026 10:16 amDo they look burned? If you measure them are they still within spec??desertmouth90 wrote: ↑Wed Sep 16, 2026 9:59 am Do you think the screen grid resistors have gone and the valves are fine?
Output Impedance error
desertmouth90
Re: Output Impedance error
I am more worried for the tubes than the resistors.desertmouth90 wrote: ↑Wed Sep 16, 2026 9:59 amDo you think the screen grid resistors have gone and the valves are fine?Roe wrote: ↑Wed Sep 16, 2026 9:37 amexactly, with this kind of mismatching you get a 8.8k load on a quad of tubes, instead of 2.2k. On a pair you get 17.6k instead of 4.4k.Helmholtz wrote: ↑Tue Sep 15, 2026 11:18 pm The higher the load impedance, the lower the plate voltage swings. When at large plate current the plate voltage swings much lower than the screen voltage, the screen current (and thus screen dissipation) shoots up, because the screen now is more attractive to the electrons than the plate.
with 470R screen resistors and 2 hours of loud clean, you can over-dissipate the screens easily.
desertmouth90
Same, £180 down the drain, I need to build a tester as the ones on the market are a rip off in the UKRoe wrote: ↑Wed Sep 16, 2026 11:06 amI am more worried for the tubes than the resistors.desertmouth90 wrote: ↑Wed Sep 16, 2026 9:59 amDo you think the screen grid resistors have gone and the valves are fine?
pdf64
Does your amp have a HT fuse?desertmouth90 wrote: ↑Wed Sep 16, 2026 8:39 am ... I have 470ohm 6W Screed Grids. Which I will bump up to 1k I think. ...
If not, 6W seems excessive, as it allows a shorted screen grid to stress the whole HT supply, until the mains fuse blows. Which can take awhile.
The Fender 6L6 screen grid resistor spec has always been 470R 1W.
If going up to 1k, they should be 2W
Metal oxide with a flameproof coating are a good choice for this application.
pdf64
A fixed bias amp with a stiff HT supply, together with a lightbulb limiter and selection of bulb wattages, and regular scope, sig gen and dummy load, can be used to check and grade output valves.desertmouth90 wrote: ↑Wed Sep 16, 2026 11:13 am ... I need to build a tester as the ones on the market are a rip off in the UK
Probably just 1 of the 6L6 has shorted.
Probably now it's a hard fault and will be obvious as soon as it powers up, but sometimes they can be intermittent shorts, only flashing over under heavy usage.
3 others liked this
Doubling Zaa more than doubles screen dissipation, assuming no screen grid resistor. Screen resistors will help (reducing screen voltage and lowering the plate curves), but the screen grids are still at risk if the load line crosses much below the Vg1=0 knee.Helmholtz wrote: ↑Tue Sep 15, 2026 11:18 pmThe higher the load impedance, the lower the plate voltage swings.
desertmouth90
So you think there is a chance the valves are all fine?pdf64 wrote: ↑Wed Sep 16, 2026 11:52 amA fixed bias amp with a stiff HT supply, together with a lightbulb limiter and selection of bulb wattages, and regular scope, sig gen and dummy load, can be used to check and grade output valves.desertmouth90 wrote: ↑Wed Sep 16, 2026 11:13 am ... I need to build a tester as the ones on the market are a rip off in the UK
desertmouth90
Yeah I put two HT fuses inpdf64 wrote: ↑Wed Sep 16, 2026 11:43 amDoes your amp have a HT fuse?desertmouth90 wrote: ↑Wed Sep 16, 2026 8:39 am ... I have 470ohm 6W Screed Grids. Which I will bump up to 1k I think. ...
Good! The obvious question is are they blown? How about the mains fuse? A fade to silence sounds more like a mains fuse, with diminishing volume as the filters drain, but I suppose the same thing could happen if you just lost the HT.
desertmouth90
all fuses are fine, I dont get it... HT and Mains (and I know what the burnt ones look like as I kept them haha!)martin manning wrote: ↑Wed Sep 16, 2026 12:43 pmGood! The obvious question is are they blown? How about the mains fuse? A fade to silence sounds more like a mains fuse, with diminishing volume as the filters drain, but I suppose the same thing could happen if you just lost the HT.
Ok, the place to start is remove all tubes and check voltages at all of the power supply nodes including the bias supply.
pdf64
A failed fuse can appear fine.desertmouth90 wrote: ↑Wed Sep 16, 2026 12:56 pm ... all fuses are fine, I dont get it... HT and Mains (and I know what the burnt ones look like as I kept them haha!)
Please check them with a meter.
pdf64
Perhaps 3 of the 6L6 are fine and only 1 may be dodgy.desertmouth90 wrote: ↑Wed Sep 16, 2026 12:19 pmSo you think there is a chance the valves are all fine?
desertmouth90
Im very silly, I forgot I added 1ohm biasing resistors so this should be easy to work out.
Ill post my Voltages, mVs (mAs) later tonight. im still at work obsessing over it.
Once good fuses are installed, and after you've done Martin's checks, I suggest you power up via a lightbulb limiter and watch the 6L6 carefully for flashover.desertmouth90 wrote: ↑Wed Sep 16, 2026 2:12 pmIm very silly, I forgot I added 1ohm biasing resistors so this should be easy to work out.pdf64 wrote: ↑Wed Sep 16, 2026 2:08 pmPerhaps 3 of the 6L6 are fine and only 1 may be dodgy.desertmouth90 wrote: ↑Wed Sep 16, 2026 12:19 pm
