Cash in hand
Andy Le Blanc
Re: Cash in hand
Post by Andy Le Blanc »
close tolerance with the test fit... 1/4 inch
combos are tricky to scratch build as a one off, if it didn't fit I'd be screwed.
I'll plan the next one much looser, it'll make for an extra inch, maybe just
plan the speaker board differently, one board width can make the difference
lazymaryamps
Phil_S
Re: Cash in hand
Post by Phil_S »
Hey Andy, I think this one qualifies as amp humor. Gosh, did you ever get lucky. Even luckier if there is no unwanted magnetic coupling. Good luck!
Andy Le Blanc
Re: Cash in hand
we'll see...
lazymaryamps
Andy Le Blanc
Re: Cash in hand
happy find at micheal's crafts... they have over to the crafts a selection of birch plywood
that gets incredibly thin... 32nd's and 16th's... great for amp dashboards
easy to work, glue on or attach with the pot nuts... easy to apply art to, kind of nice.
lazymaryamps
Regan
Re: Cash in hand
Post by Regan »
Double stick tape works good with control panels too :)
Nice amp!!!
Regan
Andy Le Blanc
Re: Cash in hand
pictures and progress
lazymaryamps
Andy Le Blanc
Re: Cash in hand
a couple more of the dash
I couldn't find a finishing washer for the pilot, so I made one out of a mic stand nut
lazymaryamps
Colossal
Re: Cash in hand
Post by Colossal »
Very nice Andy, thanks for sharing those. Is the preamp board material masonite?
Andy Le Blanc
Re: Cash in hand
the issues that have come up so far have been standby pop, presence pot scratch and heater hum.
standby pop is a one cap fix
the client wanted a old fashioned presence control, but boy oh boy...
I'd forgotten just how apparent the scratch could be, voltage one the pot...
I'll be fixing that..
I'll put in a hum pot too, I'm on the fence whether to reference it to ground or -/+
the only real mod from circuit is how I have the screens, a 470r series resistor
and a bleeder to ground before the screen grid resistors , keeping the screens 5-10 v negative relative to the plates,
zero signal at the selected bias point for the power supply... Tube type doesn't matter (with exception of ideal loading) if you bias the PS to a consistent point and maintain the
screens relative to the plate at that chosen operating condition
The PCB is hard board (turd board), actually has an electrical rating that improves with age. a vintage character thing.. too funny
lazymaryamps
rp
Re: Cash in hand
Post by rp »
Does that thin veneer drill ok, cutting edge of bit doesn't catch and tear or break it? How'd you do the graphics? Looks nice BTW.
Andy Le Blanc
Re: Cash in hand
getting there still some clean up to do and some value substitutions
lazymaryamps
Colossal
Re: Cash in hand
Post by Colossal »
Andy, thanks for identifying the board material. That looks slick. I like the Faraday coil around the tone stack leads!
Andy Le Blanc
Re: Cash in hand
It's plywood... and it was fine to machine, surprisingly.
I cut it to size, clamped it the chassis and drilled it in place using the chassis as a guide, using a stepped bit.
The lettering is just pencil and a stencil, under a quick coat of poly...
keep it stupid,.. simple
Most issues are resolving, hum pot helps... still have to chop stick for hum
may replace a few grid leads with shielded cable.
Still on the fence about the bass response, cap values post of, and the input cap of the phase invertor.
already been trying out 12ay7 in the pre and 820 vrs 1.5k at follower driver.
been liking a 12ay7 in the first stage, its from a twin 5e8-a, and a 12ax7 follower.
most else is coming together. I be back onto finishing the cabinet
the tight coil around the tone stack leads does seem to help, more for shielding,
but I know it effects tone a smidge,
oh ya turd board.. theres such huge variety in vintage amps, and none of it is any good, the capacitive effects of the crap materials that end up inside of amps does effect tone, its stupid... but it does, you don't necessarily want quality, for the tone...
lazymaryamps
Andy Le Blanc
Re: Cash in hand
a few changes very near the completion.
lazymaryamps
Andy Le Blanc
Re: Cash in hand
It seemed to settle out on .047uf caps on the power side, and a .0047 input cap to the invertor.
Theres a good deal of variation thru out fender and marshal...
Installed shielded cable on the grid lead of the follower, from the tone stack to the input of the invertor,
and the grid lead of the input side of the invertor.
between this and a 250r hum pot, got the rig down to nearly hum free.
lazymaryamps
