Dave, you are specifying the PT voltage and current, so that implies loaded condition. Therefore, I think the 1.3 factor in your voltage calc should be 1.41 for silicon rectifiers.Colossal wrote: ↑Fri Aug 16, 2019 5:07 pm I've been spec'ing transformers with Phil from Heyboer. OT will be a Dynaclone A451 at 2k2. Power supply will be SS full wave rectified into a CLC filter. Then B+ to OT. Choke will be rated for 500mA.
I will be running a quad of Winged C 6550s. Max dissipation is 35W. The datasheet specifies the U/L application at either a plate voltage of 560V for 100W or 450V at 70W. Any thoughts on the operating point? (Ian, Tony, Leo, et al)?
For the PT, I am specifying either 400VAC or 410VAC at 450-500mA secondary, a 55VAC bias tap, and two 6.3VAC taps; one for heaters (9A) and the other for accessory stuff (3-4A).
For my bar napkin math using a 400VAC secondary...
With a 400VAC secondary, 400 * 1.3 = 520VDC rectified under load
520VDC across a CLC = ~ 10VDC drop
510VDC B+ to OT centertap
~ 500-500VDC plates
~ 224VDC screens @ 43% screen taps
~ -60VDC bias
Your "224VDC screens @ 43% screen taps" does not make sense to me; In UL the quiescent screen voltage is essentially the same as the plate, and the screens are supplied through the OT primary, so you don't need a choke.
You will have to derive a reduced voltage for the preamp, though, and there are a couple of options there. The simplest is a big dropping resistor RC, but you could also use a CLC.
Refer to the snip below from GE 6550A data sheet for two tubes in UL. I would target the operating point suggested there. You can basically double the values for current, except reduce the zero signal current by ~20% due to the 35W vs. 42W Pa max. Note the max signal current (Ia + Ig2) is about 300mA, so 600mA to you. I think your PT should be rated for 325-0-325 @ 600mA (around 350V unloaded) to get ~450VDC under full load. The output power will be around 140W, 2x what's shown there.
If you want to go with the SSS-type drivers, you could have your PT wound with two extra taps at 120-0-120 for the CF driver positive and negative voltages, like a dual voltage secondary.
I haven't come across the driver circuit shown above. Where did that come from, and what are the values of the unmarked resistors?
