There are many kind of feedback that have been imported from Hi-Fi and then forgotten (even in Hi-Fi). They will sound with the input capacitance of a pentode, the available power of a pentode and the loadline of a triode (more or less depending on the amount of feedback): implement it badly once, and no one will use it again.
Also, consider that it will clip differently than an amp with the standard feedback from secondary to the previous stage, and differently means that people are not used to that sound, so again a good idea can have troubles finding its way in a certain specific field.
Another further point: Shade proposed originally his idea for the 6L6 family of tubes and SE applications in Hi-Fi, so a (known as) 6L6GC based clean amp experimented it. Like the Fender UL experiment (most probably there to save one choke and get a cleaner power amp).
Just one point: Shade idea is to have local feedback on an output tube to linearize it using parallel feedback (and so more current to drive it), but you can also swing more voltage with a series feedback (it gives the opportunity to squeeze more power with a particular configuration): there are really many many ways to get same results.
