For some reason, I am getting no voltage on pin 6 of both V1 and V2 (cathodes) and hence no signal. From pin 8 of V2 forward, there is no problem with the amp. I have replaced the wire, the resistors, the cap, the tubes, and still no signal. Help...
Ya, it looks like you have your cathodes and plates swapped - pin 6 on V1 connects to the first board component on the right which goes to ground. On 12A*7 type tubes : 1,6 - plates ; 2,7 - grid ; 3,8 - cathode.
KT66 wrote:Ya, it looks like you have your cathodes and plates swapped - pin 6 on V1 connects to the first board component on the right which goes to ground. On 12A*7 type tubes : 1,6 - plates ; 2,7 - grid ; 3,8 - cathode.
Also, if you used shielded cable on your input, be sure that the braid is trimmed back at least 1/8-1/4" from the inner conductor, then heat shrink it.
Some cables have a conductive layer over the inner conductor insulation to prevent noise.
If yours has this it must be trimmed back or it can short the input to ground.
Structo wrote:Also, if you used shielded cable on your input, be sure that the braid is trimmed back at least 1/8-1/4" from the inner conductor, then heat shrink it.
You guys are great! Thanks. The amp sounds great,but I am getting some hum from the V1, V2 Filaments. I think I will experiment with feeding the filaments from above and see if that quells the noise. It is only audible if I put the gain above 1:00PM and crank the Master at 10:00.
I will definitely strip back the wire more and heat shrink it. First i want to get rid of the hum and then I will do a majo clean up and post some pics and clips....
