This weekend I bought a hardwood Boogie MKIIB #7069 and I've got some issues with it.......
The amp has me a little puzzled, so I need some advice from those here who have more experience with them. If anyone can help me out I'd very much appreciate it. I'd also like you to look at the amp and determine if it's original or modified in any way, which could explain some things.
I'll list my concerns in order.
1. The reverb is quite weak, even on 10 on the clean channel it's not that present, but when going to the lead channel it then sounds swampy.
2. On the clean channel, it gets louder up to about 4 on the master, but then after that, any further master increases have no effect.
3. The lead channel lacks gain, with the first volume on 7 and the lead drive on 10, there really isn't enough gain for the kind of lead lines I play. Only when adding the boost function can I get close to enough gain.
4. The lead channel is very dark and muddy, I'm struggling to get any crispness out of it. If I eq the lead channel for enough gain and top end, my clean channel is really toppy.
The amp looks original inside, see pics below. The amp is currently running all NOS Phillips 12AX7's in the pre-amp and Sovtek 5881WXT's in the power (I will change these). I have questions too about the ins and out's on the underside of the chassis. There are THREE RCA phono connections underneath the chassis, the reverb tank plugs into two of them, one is un-used? I also have two 1/4" jack sockets under there, one labelled pre-amp and one labelled Boost & Graphic. I had thought that it was supposed to be Reverb & Boost?
Anyway, I hope you can help me guys, I'm digging the clean channel and the added boost with my 335, I just need to get to the bottom of the reverb and the lead channel really, as well as understand what's going on underneath.
Front:
[img
Back:
[img
Ins & Outs underneath - The RCA phono on the left is not currently being used:
[img
Chassis underside:
[img
Inside:
[img
Cable from Reverb Tank, NOTE bare blue wire....
[img
Reverb connected:
[img
Rob
