I need a roadie in my shop for moving this one around. Its a George Dennis Bassic Tube 120. I did not weigh it but I swear it is heavier than a Twin Reverb Combo with JBL's - and this is just a head!
Its a rugged amp and not hard to work on. Pre-amp sockets are crap and soldered to the board though. After resoldering it came alive. Those trannies seem overkill for the rest of the rig. I have no idea if the weight is from the wire in the transformers or from the fortress surrounding them. Glad I don't have to move it beyond the door to my shop. Even the shell weighs a lot! An Eastern bloc SVT! (Hope that's PC, sorry if not, no offense) the manufacturer was kind enough to send a schemo, although it was the wrong one and luckily not really needed.
Boat Anchor
Boat Anchor
Re: Boat Anchor
Offensive? It wasn't. Anything not offensive isn't funny anyhow.
WTH are those things where the transformers should be?!! heh
Wow. Is that thing UL output and have you compared it to a Marshall Major? Even the tube placement makes me think I know about how heavy those are.
Re: Boat Anchor
Its not UL. Got 2k/5w screen resistors per tube and 250Uf (totem with 2 500uF@ 500V )of power tube filtering. You could arc weld with this amp.Reeltarded wrote:Offensive? It wasn't. Anything not offensive isn't funny anyhow.
Re: Boat Anchor
Wow!
That is a beast!
I take it that it is meant for bass guitar?
Is this the same amp?
[img:285:303]http://www.georgedennis.eu/images/bass2.jpg[/img]
That is a beast!
Re: Boat Anchor
Here is a manual in case you don't have one.
Re: Boat Anchor
I've built a few amps using Roget's Thesaurus as a guide.
I'll get back to you on the results later...
Re: Boat Anchor
hahahaa! I just snorkled.
Re: Boat Anchor
Close. The difference appears to be the tube type. I am working on the 120 (El-34). I think it is a bass amp. Note the Speakon connectors.Structo wrote:Wow!
That is a beast!
Re: Boat Anchor
I knew someone would comment on that! I think its time I built an amp cradle and get away from book shims!Cygnus X1 wrote:I've built a few amps using Roget's Thesaurus as a guide.
