Wire Preference
Reece86
Wire Preference
Post by Reece86 »
Hey all
Spent some time on here before, then I took what I learned and built a fuzz pedal and took apart the amp I was making... Starting it again from the populated turret board and going to do a completely new lead dress.
Before I get into that project, I was just wondering what wire selection people are using? I am making a 5F1(ish) build, and was thinking cloth wire could be a fun throwback.
So what are your thoughts? Wire, PVC, Teflon, Solid or Stranded?
Thanks all!
dynaman
Re: Wire Preference
Post by dynaman »
I like stranded teflon. Good memory and holds up to heat well.
ToneMerc
Re: Wire Preference
Post by ToneMerc »
dynaman wrote:I like stranded teflon. Good memory and holds up to heat well.
Same here, my first two builds I used cloth wire and I have never returned to it. I have no plans to return to it either. I did use solid PVC in my Express build though.
TM
Milkmansound
Re: Wire Preference
Post by Milkmansound »
I've been using cloth covered mojotone wire exclusively for years. For the ground and higher current power supply stuff I use the CE 18ga cloth wire.
looks great, stays put, and sounds right for Fender stuff
David Root
Re: Wire Preference
Post by David Root »
20 ga. solid, silver plated, teflon insulation. From Steve at Apex Jr., best price there is.
Cloth covered wire is for restorations only IMHO.
Randall
Re: Wire Preference
Post by Randall »
+1 for the Mojotone cloth solid. Good stuff IMHO. Also have some of the Apex teflon 20g for newer stuff.
sepulchre
Re: Wire Preference
Post by sepulchre »
20ga solid teflon is what I've been using. Stranded is okay too; I just like working with solid.
Tried cloth but how good it is really depends on where you get it - some has over sized insulation, others look too small. I've not tried Mojo's though.
I'd like to try some high temp PVC just because it's recommended by Ken Fischer, Howard Dumble too, I think. But not sure where to get it.
20ga for all except entering power and heater wires. 18 for the heaters, at least to the power tubes, then sometimes go down to 20 for the preamp tubes.
Here's a gauge table for current capabilities: http://www.powerstream.com/Wire_Size.htm
davent
Re: Wire Preference
Post by davent »
For heaters 20awg Belden PVC solid core and for pretty much everything else, stranded 22awg PTFE (Teflon) from Apex Jr.
dave
Re: Wire Preference
I don't use one type of wire on a build. Use 20 ga solid pvc for mini toggle wiring and under board wiring, 20ga topcoat stranded pretinned for most connections, 20ga PVC stranded on switches, and 18ga pretinned for filament.
I've got a bunch of different types of wire rolls, PCV, Topcoat, Teflon and some unknown stuff. I think I bought too much wire actually. :roll:
labb
Re: Wire Preference
Post by labb »
20 ga. 600volt, pvc, tinned copper solid
Ga. capacity
18 16 amps
20 11 amps
22 7 amps
24 3.5 amps
26 2.2 amps
All data from 1978 ARRL Radio Amateur's Handbook or computed from data there
sepulchre
Re: Wire Preference
Post by sepulchre »
Hey Mark, when you say 'pretinned' do you mean stranded?
labb - where do you get 600V PVC? All I can find is 300V.
labb
Re: Wire Preference
Post by labb »
McMaster Carr. They will sell in minimum lengths of 25 foot. Have almost every color.
sepulchre
Re: Wire Preference
Post by sepulchre »
Thanks buddy!
Re: Wire Preference
It is stranded but the wire is tinned during manufacturing process before jacket is applied to the wire. I just prefer working with it.
sepulchre
Re: Wire Preference
Post by sepulchre »
Thanks Mark. I've used pretinned wire before, in fact I think that's about all I've got right now. I just didn't know if you meant stranded. It might sound obvious but I do have some solid that's pretinned too.
I might try some of the irradiated PVC stuff that labb recommended. It comes pretinned as well and is not too pricey.
