Extra wide board material.
You guys had talked about were your were getting some board material cut . You could get it extra wide.
For the life of me I cant find that conversation again.
Thanks Bill
Thanks Bill
Re: Extra wide board material.
Thanks Mark
I wanted to try the the large hole cutout with the pre amp tubes down below.
Looked interesting in that discussion what they were doing.
It gets my pre amp tubes closer to the front and kind of a point to point style up to the board.
Bill
Bill
- JazzGuitarGimp
Maybe another sub-forum called RESOURCES could be created for this. The subject line of each post could be a brief description of the part / material, i.e. Custom Sized Turret Board Material, or JMP Chassis, M150 series Capacitors, etc. Then people can post comments on where they get theirs, the perceived quality, cost, value, etc…?
I know I've had the same experience as Tone Lover in that I remember reading about a source for a particular part, then could not find the discussion with the search function.
Just a thought.
Just a thought.
Lou Rossi Designs
and Schematic Capture
If I remember correctly you are talking about this : https://www.tubedepot.com/products/1-8- ... ural-color cheap!Tone Lover wrote:You guys had talked about were your were getting some board material cut . You could get it extra wide.
Thanks Bill
looks like this :
Good thinking because you have spent the time to find the resources then tell us and when we try to use them. Then we cant find were they were. Most of the time I will bookmark that discussion under my amp parts or amp building knowledge section on my computer. but I found it at work and forgot to,when I got home.\JazzGuitarGimp wrote:Maybe another sub-forum called RESOURCES could be created for this. The subject line of each post could be a brief description of the part / material, i.e. Custom Sized Turret Board Material, or JMP Chassis, M150 series Capacitors, etc. Then people can post comments on where they get theirs, the perceived quality, cost, value, etc…?
Just a thought.
Thanks Bill
- JazzGuitarGimp
The Mod and the Party Line!Structo wrote:The search function works great!
![Laughing :lol:](./images/smilies/icon_lol.gif)
It might work great if there weren't 10 bazillion (bazing!) posts here...
Last edited by JazzGuitarGimp on Wed Feb 05, 2014 5:40 pm, edited 1 time in total.
Lou Rossi Designs
I second that it doesnt work well enough.JazzGuitarGimp wrote:The Mod and the Part Line!Structo wrote:The search function works great!![]()
Found a better supplier at almost half the price
http://www.eplastics.com/Plastic?search=g10+.080
- Milkmansound
I just ordered 12 of each sized board I use from eplastics - cost was about $250 so a little more than $5 per board
Compare that to watts prices and it's a no brainer
- Jack Hester
Thanks for the source. I bookmarked it, and will definitely be buying from them.Milkmansound wrote:I just ordered 12 of each sized board I use from eplastics - cost was about $250 so a little more than $5 per board
Here's the link for others:
http://www.eplastics.com/G10_FR4_Glass_Epoxy_Sheet
Thanks, again.
Jack
I apologize,
I did do a search and it wasn't that fruitful.
So yes,
www.turretboards.com
www.hoffmanamps.com
www.Mcmaster.com
are all good sources for board material.
So yes,
www.hoffmanamps.com
www.Mcmaster.com
Be careful when you cut that stuff!
The dust is not good for your lungs...
I second what Ken just said, real nasty would be better put .Ken Moon wrote:Be careful when you cut that stuff!
Bill
