Single ended amp Filtering and Tremelo Questions
yalesmith
Post by yalesmith »
Hello. I have to questions and thanks in advance. I purchased an old single ended amp (EL84) on eBay and it worked fine aside from the tremolo circuit and it needing a re-cap job.....volume fluctuations, excess noise, etc.
Question 1:
The recap job calls for 3 20uf cap in a single can but I was unable to find such a cap. I was able to get a JJ cap that has 3 20uf and a single 40uf. I was wondering if I could use the 40uf for some additional filtering? If so how would i use it.
I attached a part of the schematic for your review.
Tremolo:
I have a few of these old Japanese amps and the none of the tremolo circuits work. Where do i begin to trouble shoot the problems? I have no idea how these circuits work.
eniam rognab
Re: Single ended amp Filtering and Tremelo Questions
Post by eniam rognab »
c17 is 40uf :D
Stevem
Post by Stevem »
Antique electronics supply carrys a 20/20/20/20 475 volt can cap.
parrallel two of the 20s to feed the second node which should be the output tube screen supply.
If this amp is like all the Jap univox /Lafayette amps of the mid 60s than all the caps are oil types that go bad, but sound killer until they do.
Replacing c14, c15 and c16 should get the tremolo back up and running, but if I am right about the oil cap thing, than at some point plan on changing them all out.
also make sure you do not need a foot switch to close the circuit to get the tremolo going as I did not look at the schematic.
Good luck to ya!
Oh by the way, if you need help I work at ALTO MUSIC in your neck of the woods.
yalesmith
Post by yalesmith »
Ha! Yes did not even see that. I was confused as it was a circuit board and the other 2 20uf caps were on the other side of board, I really hate following traces. Now all i need is to use the jj can cap and run wire to the circuit board. That was very silly of me. To get the 40uf they ran to 20uf in series....I fished old can out of garbage.
yalesmith
Post by yalesmith »
Steven.... Hey Alto is a great store! The prices are better then what you can find online. If you work in the Rockland store we definitely talked before.
tubeswell
Post by tubeswell »
With the tremolo, the first thing to try is a change of trem oscillator tube.
If that doesn't work, then you need to look at the power supply (including filter caps), heater circuit, and the LFO circuit R/C network and how the LFO couples to the signal path (i.e.; such as whether it uses a roach/opto-isolator if it has one, or whether it wiggles the bias on one or more signal stages etc)
Stevem
Post by Stevem »
Note that caps in serise halve the valve, not double it.
to get 40 uf from two 20 uf caps they must be in parrallel.
I work over in the Middletown store doing repairs and QC on there line of mics and 500 serise modules.
