Engl 520 preamp
- schaublin65
Engl 520 preamp
Hi,
I have been playing with this circuit for the last few evenings.
There is an interesting component I had not seen used in this way.
A small inductor between signal and ground.
It's a little black cube about 8mm on each side. Marked LT 3011/2.
I don't have an LCR meter so I will have to rig something up to measure what it's doing. Lifting one leg off the board it seems to make little enough difference.
Take care
John
Take care
John
Re: Engl 520 preamp
It is an optoisolator. It is probably used for some kind of volume switching, but hard to tell without the whole schematic.
I Think I Think Too Much !
Re: Engl 520 preamp
Exactly. Here you can find photo and specs:
http://www.griotgroup.com/wp-content/up ... ors-07.pdf
- schaublin65
Re: Engl 520 preamp
Hi,
thanks for taking the time to reply.
I have edited my posts in this thread because they contained no useful information.
Old test equipment and confirmation bias is a troublesome combination.
The purpose of LT is presumably for stability when V3a is switched out.
Take care
John
Take care
John
Re: Engl 520 preamp
This is the schematic, but it's not 100% correct.
http://milas.spb.ru/~kmg/files/schemati ... ematic.pdf
[img
850]http://rudn.nodevice.com/preview/big/372/372820-1.jpg[/img]
[img
- schaublin65
Re: Engl 520 preamp
Hi
post edited, see fourth post in thread
Re: Engl 520 preamp
Have you tried to place a capacitor in parallel to the inductor, and calculate its value once you have determined the resonance frequency?
- schaublin65
Re: Engl 520 preamp
Hi,
sine wave generator recap in progress...
[img
1536]http://i.imgur.com/6ugGJHo.jpg[/img]
take care
John
[img
take care
John
- schaublin65
Re: Engl 520 preamp
Hi,
- schaublin65
Re: Engl 520 preamp
Hi,
post edited due to strange results from these
[img:542:720]http://i.imgur.com/wJYnI8r.jpg[/img]
more work required
more work required
