channel switching in a 3 or more channel amp
idnotbe
Post by idnotbe »
after searching a little bit, i noticed many 3 channel amps use 2 relays for the channel switching.
1st relay : CH1 (clean) <-> CH2/3 (dirty channels)
2nd relay : CH2 <-> CH3, when the 1st relay selects CH2/3
but it is somewhat weird, because the player will regard the 3 channels as triple parallel.
and some complicated amps have 4 or even 6 channels in one amp.
so, i wonder... what's the best way to implement 3 or more channels in parallel in one amp?
Re: channel switching in a 3 or more channel amp
A small Arduino or similar programmable computer would do the trick. It can control any number of relays using any number of foot switches.
